Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Subs pop
Old Oct 7, 2008 | 05:27 AM
js_iron's Avatar
Subs pop
I have on 04 TRD Prerunner. I installed my system yesterday & I am concerned over something. I have two 10" Punch's with a 500 watt amp & Kenwood deck. I've had the same system in my past several vehicles, so I know its a good system. My concern is that when I turn the truck off the subwoofers make a popping sound & jump. I noticed that when you play with the RCA jacks it will do the same thing. Never had the problem before. Any help?
Old Oct 7, 2008 | 07:46 AM
scuba's Avatar
sounds like interference to me
Old Oct 7, 2008 | 09:40 AM
nieuwendyk-25's Avatar
Make sure everything is grounded good! Amp, Head unit, Etc.
Bad grounds cause all kinds of weird issues and noises.
You also might try a different set of RCA's just to rule that out.
Old Oct 7, 2008 | 11:02 AM
hross14's Avatar
They might of also left in the small helper amp toyota sometimes uses. I has the exact same problem and that was what the problem was.
Old Oct 7, 2008 | 11:17 AM
mrtejman's Avatar
Did you run your RCA cord next to your power cord?
Old Oct 7, 2008 | 12:33 PM
scuba's Avatar
That sounds most reasonable to me, never do it, just causes interference, as I stated above
Old Oct 7, 2008 | 03:10 PM
mytyeerinpie's Avatar
Ground your RCAs.
Old Oct 12, 2008 | 07:17 AM
js9924's Avatar
take some electrical tape or heatshrink wrap and put it over your connectors on the RCA's I had mine bump each other occasionally and produce a similar effect.
x2 on the grounding make sure you have a good connection take some sand paper and clean up the area where your ground wire contacts the chassis.
Like scuba said dont run the rca's next to the power wire or anything else for that matter and if you can get the twisted RCA's they cut down on interference.
Old Oct 15, 2008 | 07:32 PM
drpdmazda's Avatar
sounds like a ground loop to me. check all your grounds as stated before, also if you have more than one amp make sure they are both grounded at the same spot and that you have a solid ground point, all paint removed etc. also try grounding your headunit somewhere else.
Old Nov 4, 2008 | 09:54 AM
js_iron's Avatar
Fixed it. Thanks for the help. Loose RCA behind radio.
Bourbonblues
Dec 15, 2017 05:43 PM
mluz013
Sep 29, 2015 05:53 PM
kawazx636
Sep 29, 2015 08:22 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
