Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Power Antenna Problems
Old Jun 3, 2006 | 07:42 AM
NOVA Runner's Avatar
Just swapped out my OEM ('01) head unit with a new Sony (Sony CDX-GT705DX) followed directions exackly (wires were soldered, heat shrinked).
Now the power antenna does not go up when head unit powers up. I used the Metra Toyota plug adapter connectors.
Any ideas what is wrong?
Old Jun 3, 2006 | 09:10 AM
Bigvick's Avatar
Put your head unit on tuner. My Alpine HU only raise the antenna when your listening to the radio, then as soon as you change to a cd or other source the antenna goes back down.
Old Jun 3, 2006 | 09:11 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
mine only goes up when on tuner as well. some others put it up any time the HU is powered on. Try the tuner thing and let us know.
Old Jun 3, 2006 | 02:11 PM
thanks for the response, but I had tried that before with no luck.
Connected the p.ant lead from the sony to the Mitra connector for antenna - the opposite side of the connection has a jumper connection from the vendor, do not know why. I'm going to meter the wire for power output.
Anyone know if the power ant lead has permanent power when on tuner or if it just sends a signal (relay, etc.).
Thanks
Old Jun 3, 2006 | 02:25 PM
Localmotion's Avatar
I think it just sends a signal. I have a sony HU now and I had a cable that pluged into the power antenna. Hope you get this solved.
Old Jun 3, 2006 | 04:58 PM
Wink
What do you mean- cable? Bypass from the head unit or a custom power lead run on it's own?
Thanks, nice shot!
Old Jun 3, 2006 | 05:10 PM
Thanks, nice shot!
I had a wire coming out of the HU that pluged right into the power antenna.
Sorry I cant help anymore.
Old Jun 4, 2006 | 07:18 AM
Bumpin' Yota's Avatar
ok all aftermarket decks have a solid blue wire, that solid blue wire is for your power antenna. This blue wire will essentiall produce 12v whenever you have your tuner on.... Ill post back with what color the toyota p antenna wire is...
Old Jun 4, 2006 | 07:21 AM
ok heres the wiring code for an 89 toyota...
12v contant - Blue/Yellow
Accessory - Gray
Ground - Brown
Power Antenna - Black/Red
Illumination - Green
Dimmer - Blue/Yellow
Left Front Positive - Pink
Left Front Negative - Purple
Right Front Positive - Light Green
Right Front Negative - Purlple
Left Rear Positive - Black
Left Rear Negative - Yellow
Right Rear Positive - Red
Right Rear Negative - White
Jun 1, 2021 01:51 PM
Sleaker
Aug 26, 2020 06:03 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
