Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
My Future System....research in progress...
Old Jan 6, 2005 | 12:01 AM
Ajs DrtyRig's Avatar
Question My Future System....research in progress...
Yo everybody, whats going on. Well I am and have been researching for the next system since mine is going to ˟˟˟˟s... I plan on using this thread to ask questions that I have for I am no where close to understanding how alot of this works...
I went into a local audio store to listen to some componants, i will go into more depth later, but i explained to him what amps i have currently and he immediatly said sell them...
* Question 1*
Id like to know if this first amp is an okay amp for running a nice 2-way compon. system such as Dynaudio or Diamond or maybe the focal utopias or MB Quarts Q-LINE...
Its an a/d/s 8ch...here are the stats about it.. the same goes for my mono-block, the JBL 600.1...i will ask more questions after i get an understanding about these amps...thanks guys
a/d/s
Amplifiers
P840
Number of Channels 8
Individual Channel Power Output into 4-Ohms (RMS 20-20kHz @ less than 0.3% THD) 8 X 40W
Individual Channel Power Output into 2-Ohms 8 X 60W
Power Output into 4-Ohms of each Bridged Channel-pair 120W
Minimum Recommended Impedence 2-Ohms
s/n Ratio (Ref. Full power) > 100 dB
s/n Ratio (Ref. 1W) > 90 dB
Input Impedence 47k-Ohms
Crossover High-pass Ch. 1-6: 45Hz-5kHz @ 12dB per octave
Crossover Low-pass Ch. 3-8: 45Hz-5kHz @ 12dB per octave
Dimensions 10-1/2" X 14-7/8" X 2" (266mm X 378mm X 50mm)
* Specifications given for 12.0 V DC power input.
*Second Question*
With this JBL 600.1, im looking to run one ten or one twelve in a sealed box....thanks
Manufacturer Sku:
BP 600.1
Brand:
JBL
Product Line:
Power Valve
Model:
BP 600.1
Min Frequency Response:
10 Hz
Max Frequency Response:
0.32 KHz
Bridgeable:
Yes
Input Voltage:
4 Volts
Signal to Noise Ratio:
100 dB
Features
Bass Boost:
Yes
Fuse Rating:
2x30 Amp
Wire gauge:
Output Power
Bridged Power (Watts x Channels)
600 x 1
Power at 2 Ohms (Watts x Channels):
600 x 1
RMS Power Output (Watts x Channels):
300 x 1
Crossover
Built-in Crossover:
Yes
Dimensions
Height:
2.7 in
Depth:
12.56 in
Width:
9.06 in
-Alex
Old Jan 6, 2005 | 12:12 AM
Bigkahuna808's Avatar
you have alot of plans but your looking at two differces in spending. The ADS components are good, but are being bested by other brands in the simalar price catagory. The Dimaond Audio Hex rock (I run them, they are very clean, and get loud with the right wattage), also good are the rockford fordfosgate RF componets are decent, Rainbow seperates rock, and of course the focal utopia are great. But they all need power. You need a strong amp that puts out what it is supopsed to put out. None of thoes crap amps like lanzar that say 1000 watts but only put out 300. I recomend the following amps for you componets, any eclipse, that new brand focal distrubites (forgot the name, but they are bult like tanks), if you can fit them in your install the new Rockford Power amps are very underrated (big power out of a lower claimed wattage. My amp said 1000 out put was like 1314 watts.), or the Diamond Audio amps.
The big thing is always price, you gotta pair up quality with quality.
Old Jan 7, 2005 | 10:07 AM
Angry amps...
So you would agree with the gentleman I spoke with that i need to sell both of these amps?
Is it fair to say that if I hypothetically bought One multichannel, that I wouldnt need a mono sub amp to power the sub?
What do you guys think I could sell the a/d/s amp for?
" " the JBL amp for?
I will hopefully be able to post up a picture of the amount of space i will be craming a new amp in supposibly...
Old Jan 7, 2005 | 11:10 AM
The ADS would go for way more than the JBL. I would guess almost $200+ but you can barley get anything for the JBL maybe $100 or less
Old Jan 10, 2005 | 02:10 PM
Next Question
Thanks for the replys about the amp situation, I have figured it out. I will be keeping the a/d/s and selling the JBL. I am looking into buying the MTX 81000d.
My next question is regarding sound dampening. Has anybody on the board dampened their 90-94 extended cab pickup??? If so, i need to know how many square feet i will need to do the trucks floor, doors, and possibly cieling. I need an approx. WITH and WITHOUT the cieling....
Thanks and Does anybody live in or around the Bay Area, CA to help recomend to me a place to get my new compnants when i get them, installed???
-Alex
Old Jan 14, 2005 | 08:52 PM
98LimitedCustomized's Avatar
You should shoot for 50-75 ft of sound deadening.... and I'd install the speakers yourself. If you really take your time and deaden your doors with 20 or more square feet you'll thank yourself later- it makes your mids sound MUCH better
Peel and Seal seems to work well, I used Second Skin.... great product, but not cheap
Old Jan 14, 2005 | 09:24 PM
uboatcmndr's Avatar
I am only into home systems but from what I know it's all about the environment(deadining).
Old Jan 16, 2005 | 07:47 PM
thanks, i have found a couple products out there like brown-bread, B-Quiet, Cascade Audio, Dynamat, Secondskin....i think i am gonna get the B-Quiet stuff...here is the LINK So if i were to buy 100ft of this stuff, id have enough for 20 sq. feet on each door, the floorboard, and the headliner???
I fu**ed up on my last install with the door panels...i didnt cut them correctly. Should I salvage them and use the correct tool to make them more attractive? (which tool do the pro's use?) or should i buy new ones... does anybody know where to buy new door panels??
-Alex
Old Jan 17, 2005 | 07:18 AM
stoutshady's Avatar
For just one ten or twelve, the JBL amp will do just fine...
Old Jan 17, 2005 | 08:23 AM
you wanna buy it??? im selling mine...
Old Jan 17, 2005 | 10:42 AM
Im ghetto my soundeding material I found at the local carpet shop, did the trunk and doors for $50
Old Jan 17, 2005 | 11:04 AM
HALLER!!!!!!!!!! j/k thanks for the reply dude.
nvwiggins
13
Jun 16, 2016 03:05 PM
shooter86314
Jan 7, 2016 07:05 AM
smilen724
13
Nov 8, 2015 04:11 PM
irv
Sep 29, 2015 06:20 PM
toyhaulert100
Sep 24, 2015 07:55 PM
