Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
i want to fit a ariel drop switch
Old May 11, 2010 | 02:25 PM
kerelawsurf's Avatar
hi all i want to rig up a switch that drop's a Ariel so i don't snap it when off road i have replaced it once and to get a new one it is £45 plus carriage so has any one did this if can you please tell me the way that you have did it many thanks . the reason i want to do this mod is so i can still listen to Cd's and not the radio
Old May 11, 2010 | 02:47 PM
Tofer's Avatar
Sponsor
there should be a blue wire coming out of the back of the stereo.. put a switch in line with that blue wire and it should fix your problem.
crawlerjunkie's Avatar
I used a dpdt two way switch for my rear window that might work for the antenna
Old May 11, 2010 | 07:12 PM
Tofer's Avatar
Sponsor
Just a simple off/on switch works.... When it's off the power antenna thinks the radio just turned off, bring it down. Turn it back on up it goes.
Old May 12, 2010 | 09:59 AM
thanks once agan i will sort it out this weekend
Old May 13, 2010 | 10:26 PM
Ron Helmuth's Avatar
see Rock Slide thread on Combine Antenna Signals-it's designed for our 3rd gen 4Runners but if you follow along it also gets into a toggle switch for the power antenna-what I think you refer to as aerial. I did this and my power antenna rarely ever gets switched on to come out of the fender now.
okamikai
Apr 30, 2018 10:19 PM
ghostmoney
Jan 28, 2018 11:42 AM
TDonkey
Jul 26, 2015 10:14 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
