Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
HELP!!! (stereo wiring)
Old Jan 12, 2005 | 05:38 PM
Mac6135's Avatar
Hey guys,
tore apart the 4runner tonight in hopes to wire my amp. I would post this in stereo section but I dont get many replys and I need the truck to be back together for tomorrow morning. I have the back of the stock stereo and I need to know which wires are the speakers (left, right front & left right back). What colors are the wires running into the stock unit?
its a 2002 4runner sr5
any help would be much appreciated!
Thanks
Old Jan 12, 2005 | 06:06 PM
Mac6135's Avatar
no one?!
Old Jan 12, 2005 | 08:35 PM
fiveofeen's Avatar
well if you have no other choice, remove each speaker and look at the color wire going to it. Are you installing a new head unit or just an amp and speakers. Stereo wiring harnesess arent too bad. Give us some more info an we'll try an help.
Old Jan 12, 2005 | 08:49 PM
AW1090's Avatar
usually the speaker wires are the same color just one having a strip on it. (left front speaker = red/red with black strip) the red being the positive and the red with black strip being the negative. That was just an example, but you can find all the speaker wires by this method.....if you take a 12 volt and touch the ends of it to the wires whichever speaker those wires go to will crackle. If that doesn't make sense to you then tell me and I'll try and explain it better.
Old Jan 12, 2005 | 09:03 PM
Jonathan's Avatar
The the battery method is a great way to test. The speaker wires, if I remember correctly, are purple and green, but I can't recall the other colors right now.
Old Jan 12, 2005 | 09:06 PM
bike4miles's Avatar
When I installed my sytem, the only factory wire I kept was the main power which was one of the green ones (I figured it out with a test light). I ran new wire for everything else. The stock wires are really small so I figured screw it.
Old Jan 12, 2005 | 09:08 PM
bike4miles's Avatar
Now it's comming back, isn't it: purple, green, blue, and gray for the speaker wires? It's been a long time.
Old Jan 12, 2005 | 09:23 PM
Thorsten's Avatar
Ill send you a wiring diagram tomorrow, its got all you need.
Old Jan 24, 2005 | 06:05 PM
Watts&Volts's Avatar
try this:
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Purple
Dimmer n/a
Antenna Trigger Black/White
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Doors
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
jasonty
41
Dec 23, 2018 01:00 PM
r3dfish
54
May 16, 2016 10:31 PM
theking11863
Mar 19, 2016 09:36 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Esibnitsud
Jul 30, 2015 08:19 PM
