Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Great replacement for 99+ Door speakers!
Old May 15, 2005 | 04:52 PM
DavidA's Avatar
Great replacement for 99-2002 Door speakers!
I just purchased and installed the Blaupunkt 6 3/4 components. Blaupunkt TSc660 6-3/4" component speaker system
They are on sale at Crutchfield for $59.99 a set. Awesome value. I am currently running them off of the stock radio and the sound great. Also...the tweeter has a screw-in mount that will use the factory mounting bracket...could not be any easier. I sealed the edges around the speaker to keep the woofer sealed to the door.
I also purchased the 5 1/4 separates for the rear door. Blaupunkt TSc540. I used a dremel to mount the tweeters above the woofers in the doors. They are also on sale. I think I paid like $127 shipped for both sets!
Go check them out!
I cannot tell you enough on how much better they sound than the factory. I have a new Kenwood headunit coming in to power them. I just finished a sub box for a 12" Kenwood woofer, it is being painted. And I just purchased an open box Rockford Fosgate P2002 amp for it at BestBuy for $70 off. I just finished the underseat mounting of it and are waiting for the headunit to come in.
Pics to follow!
Old May 15, 2005 | 05:39 PM
dibble9012's Avatar
When I go to "select a car" on crutchfield.com, it says they dont fit a 00 4runner. they do say the speakers fit a 02 though. anyways, those look awesome!
Old May 16, 2005 | 06:06 AM
DavidA's Avatar
That is weird....I have done both a 99 and a 2002 and the speaker setup is exactly the same. That does not make any sense.
Old May 16, 2005 | 07:04 AM
dibble9012's Avatar
well if you see "Blaupunkt TSc660 6-3/4" component speaker system" for sale, you know they dont fit a 00, hahahah
Old May 16, 2005 | 10:02 AM
DavidA's Avatar
Well, be aware on any speakers you put in the front doors is that the mounting holes do not align exactly up, you have to be creative on the angle of the screw, but they will go in at an angle or you have to make a clip on the edge to hold it down.
Old May 16, 2005 | 06:02 PM
DavidA's Avatar
Oh...for the rear speakers you can make these brackets...do and search here for the templates. I made mine.
Or you can buy them online cheap.
Ebay Link: http://cgi.ebay.com/ebaymotors/ws/eB...974013810&rd=1
Old May 16, 2005 | 08:12 PM
nieuwendyk-25's Avatar
The front factory stock speakers are 7" so you have to buy or make a bracket. That is why Crutchfield says they won't fit. Some of the 6.5" and 6.75" they will actually say fit...Crutchfield is just not consistant on the fits sometimes.
I actually have 6.5" components in the rear doors of my 2000 4runner. took a little extra work from the 5.25", which I did first, but they sound awesome.
Old May 17, 2005 | 10:21 AM
LBC994runner's Avatar
Those brackets on ebay from mjmautoinnovations work great. I have the 6 1/2 brackets on mt front doors and the 5 1/4 brackets on the rear doors of my 99 4runner.
Let's see pics of the Blaupunkts. I might consider buying them for the gf's car.
Old May 17, 2005 | 02:08 PM
DavidA's Avatar
I am going to pull off one of the panels to paint the trim around the tweeters in the rear doors. I will get some pics then of them installed. If you want to see them uninstalled look at the link in the first post.
The more I use them the more I like them. Very clean and with some actual punch on the low end.
Old May 17, 2005 | 05:42 PM
DavidA's Avatar
Ok, here are some pics of the install:
Front door, using the factory mounts.
Tweeter mount using factory bracket.
Rear door speakers using the template brackets made from MDF.
Rear door showing the component tweeters mounted above the woofers.
The Blaupunkt components really are an easy install and sound great for the price.
Old May 17, 2005 | 09:49 PM
nice install ... where did you mount the crossovers?
Old May 18, 2005 | 05:39 AM
DavidA's Avatar
Right above the woofer, sideways.
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Cplmike
Jul 8, 2015 08:47 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
