Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
extra wire on RCA cable?
Old Nov 11, 2005 | 11:55 AM
freshman's Avatar
I bought a RFosgate amp kit, question is- what's the use of the extra wire in between the RCA cable? Sorry for this stupid q....
Old Nov 11, 2005 | 12:36 PM
runethechamp's Avatar
That's the lead cable for switching on your amp with your headunit (I think that's what its called).
Old Nov 11, 2005 | 01:03 PM
freshman's Avatar
i got a different (blue) wire for that remote turn on (hedunit to amp).
Old Nov 11, 2005 | 01:17 PM
You don't need the extra one of there is one on the RCA cable already. But now you can decide which one to use yourself.
Old Nov 11, 2005 | 02:31 PM
freshman's Avatar
thanks man! i just thought that running a live wire (remote wire on?) with the rca will affect sound quality.
Old Nov 11, 2005 | 02:34 PM
I haven't noticed anything on my setup. The remote wire doesn't carry much voltage anyway.
Old Nov 13, 2005 | 10:47 AM
2000t4r's Avatar
Is the wire that you are talking about a very small wire? If so that is the ground for the RCA's ground that on the deck side.
Old Nov 13, 2005 | 12:11 PM
Cebby's Avatar
I SERIOUSLY doubt it. IT IS the turn on lead as mentioned above.
On an RCA, the pin carries signal and the outside ring is the ground.
Old Nov 14, 2005 | 11:25 AM
2000t4r's Avatar
I disagree I will take pictures tonight of my RCA's so we have all have a clear understanding of what we are talking about.
try a search on sounddomain.com or caraudioforum.com they will both give you the answers that you are looking for.
Old Nov 14, 2005 | 12:24 PM
midiwall's Avatar
It's DC.. it won't have an effect at the current/voltage that we're talking about.
Originally Posted by Cebby
I SERIOUSLY doubt it...
If it's meant to be a "ground" then it could actually be a source drain. If the amp or head floats the audio ground from the power ground then tying them together would/could avoid a ground loop.
Old Nov 15, 2005 | 02:19 PM
Gangus2006's Avatar
Its the REM Lead. Some manufacturers intergrate them into the Patch Cable for convenience, while others put them seperate to kill all possible sources of noise, and the fact that 99% of Amps have the REM slot in betweent he +12V and GND slots which is on the opposite side of the signal input/output.
Old Nov 15, 2005 | 02:56 PM
Yeah I have noticed this
Old Nov 15, 2005 | 06:04 PM
2000t4r's Avatar
http://forum.sounddomain.com/forum/u...c;f=2;t=028808
This will explain about the wires that are connected to the RCA's
Old Nov 15, 2005 | 07:31 PM
Cebby's Avatar
That gave two different opinions. Is there a right one?? If you have noise problems, there are other issues with the wiring. Using the TO lead as a ground is a patch, not a solution IMO.
coleypull15
Nov 3, 2015 07:41 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
CanRunner
Jul 20, 2015 01:29 PM
shar
Jul 9, 2015 12:38 PM
toyota32
Jul 6, 2015 05:42 PM
