Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
ERROR CODE/Toyota 4Runner 3 Disc CD Changer W/Magazine
Old Mar 20, 2005 | 11:22 AM
jc1kz's Avatar
hey guys i've the error code E 03 showing on the cd display.....it will eject the cd magazine but the cd itself stays stuck inside and won't release...any suggestions? and or if i need to take it in how much of a shock will i get? lol...any and all help will be appreciated....thanks in advance
Attached Thumbnails ERROR CODE/Toyota 4Runner 3 Disc CD Changer W/Magazine-6d54dcc3-4661-4202-8bb1-eeb0370e202c_1.jpg
Old Mar 20, 2005 | 11:59 AM
jc1kz's Avatar
bump....anyone any part time dismatlers/courious georges/radio/cd techs out there????
Old Mar 20, 2005 | 12:04 PM
4-RUNNIN' FREAK's Avatar
Did ya check to see if it is it listed in the owners manual?
I recall I had some CD error codes in mine before I lost it.
Old Mar 20, 2005 | 12:06 PM
jc1kz's Avatar
yeah i did and it just says to reinsert the magazine and then eject....but it didn't work....cd still stuck in there.......
Old Mar 20, 2005 | 12:08 PM
There may be some sort of manual button somewhere to eject it.
Old Mar 20, 2005 | 12:14 PM
jc1kz's Avatar
if there is i can't find it...i've taken the thing out and looked all over front and back...checked the plugs...short of taken it apart myself and open it...(which i don't want to do yet) i cant seem to figure it out.....i thought there was a post about someone who knew or had worked on them before....the shop alta mere says it is going to cost a small fortune to fix......
Old Mar 20, 2005 | 12:40 PM
Is an aftermarket replacement in the question? If not, maybe a junkyard?
If you do find a replacement, take the old one apart carefully with a hammer or something to get the CD out.
Old Mar 20, 2005 | 12:54 PM
jc1kz's Avatar
yeah i'm looking for a factory replacement (OEM ) same kind and will experiment with this one....a hammer huh? lol you too nice...i was thinking running it over lol
Old Mar 20, 2005 | 12:56 PM
www.OEMValue.com has some of thos older radios listed. I will try to find the exact link.
EDIT: http://www.oemvalue.com/request/toyota.htm
But the wheel may not break it, it's soft.
Old Mar 20, 2005 | 01:14 PM
jc1kz's Avatar
4-RUNNIN' FREAK your the one thanks....it has the excat unit i need thanks
man i take back every bad thing i ever said about you.....lol j/k your great
Old Mar 20, 2005 | 01:18 PM
I'd try aftermarket too for that price. It doesn't hurt to look.
www.Crutchfield.com - Not the best prices, but use for a basic idea, then you can hunt down a model number on the net for a better price.
Q: Where can I get a used stereo cheap?
A: Try your local salvage yard for a good aftermarket radio. Salvage yard's can get a good price for a factory stereo, but aftermarket stereos aren't as much of a demand with auto salvage. Usually you'll find aftermarket radios on a shelf for an inexpensive price. You can also find amplifiers occasionally as well.
From: http://www.therangerstation.com/tech...tereoFAQS.html
Old Mar 20, 2005 | 01:22 PM
Also, they do something with trades. Might want to look into that.
I wonder what I could have been paid from them for my old HU.
Old Mar 20, 2005 | 02:43 PM
AW1090's Avatar
Hey...with the old unit did you power it up, put the mag in, pull the power and then reapply power to the unit to let it reset. It may just spit the cd back into the mag.
Old Mar 20, 2005 | 02:55 PM
jc1kz's Avatar
no didn't unplug and plug it back with the magazine in it......i'll try that
Old Mar 20, 2005 | 03:06 PM
I like the gentle taps with a hammer
Old Mar 21, 2005 | 08:50 PM
nieuwendyk-25's Avatar
Eclipse makes a 6 disc unit you can install under the passenger seat. It will plug right in. Or you can do what I did and get the Alpine unit (M-Bus only) with an adapter to plug into your OEM unit from a company called Peripheral. Mine works great and will hold 3 more discs than your original unit. If I were you...before I bought anything...I would gently remove the screws and investigate the unit. If you get the stuck CD out it may work just fine. However, the original 3 disc units (actually made by Alpine) had a design flaw which was fixed on the later units. Nakamichi makes the six disc in dash unit used in some 1999 4runners, but I don't know if their unit works with the OEM plug. The Six disc Alpine unit will run you around $250 and about $80 for the peripheral adapter. Woofersetc.com has the changer for $189. They are very reliable in my experience. The Alpine unit is very reliable. If you decide to go this route let me know and I'll send you pics of how I installed mine.
Flying91
45
Apr 11, 2024 04:39 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
tobylab
Jul 12, 2015 12:53 PM
