Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Dimmer question
Old Apr 7, 2005 | 07:26 PM
Ehinfinity's Avatar
Dimmer question
Well today i got to playing around with the wiring on my 97 4runner. I have allways not like the fact that the clock does not adjust its brightness when all of the other lights do. So i tryed linking it to a switched 12volt source. Well at this point in time i think i wire came loose because its not on at all now. So has anyone else done this? Also i tryed hooking up my Alpine CD player to the same 12volt source, however it does not dim. Im going to open it back up soon and check again. Any ideas on that one?
eric
Old Apr 7, 2005 | 08:07 PM
Cebby's Avatar
If memory serves, vacuum fluorescent gauges either don't dim, or need some special dimmer to dim.
Old Apr 8, 2005 | 03:26 AM
Ehinfinity's Avatar
Well that would make sence then, thanks.
eric
Old Apr 8, 2005 | 06:23 AM
stoutshady's Avatar
At least your clock works.
Old Apr 9, 2005 | 11:36 PM
frankenrunner's Avatar
Guest
Smile
"Ehinfinity" & "Cebby"... the installation of a "rheostat"(that can be picked up from, say, RadioShack)in the circuit would work.
Old Apr 9, 2005 | 11:52 PM
green91runner's Avatar
actually, i believe cebby is right... need's to be digitally controlled, don't think it's as simple as throwing in some resistance. i believe throwing in a rheostat would effect the clocks function, but i'm not 100%
ashersullivan88yota
Jan 18, 2022 05:37 PM
JHalcyonM
Aug 4, 2015 01:19 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
