Anyone review the 4th gen JL Stealthbox yet?
http://www.jlaudio.com/stealthbox/4RUNR03.html
Contains one 10W3v2-D2 subwoofer in a sealed enclosure. 300 watt power handling. Wired for 4Ω mono. Installs in the passenger side rear cargo area. Subwoofer is protected and concealed by a color matched, carpeted, steel grille. On Limited Editions, the removal of floor package tray is necessary. Will not fit models with 3rd seating row option. Different carpet colors are offered to match the interior color of your vehicle - Taupe, Medium Gray, and Dark Gray.
Click here to Download the Installation Manual for this model
by the way that storage shelf thing (that apparently needs to be removed) in 4th gens is so cool. i test drove a 4th genner on wednesday, and was really impressed with the new features and gadgets.
unfortunately, the high pressure salesguy had me storming out angrily!
I don't have one for the reason that you mentioned...shelf has top come out and I love that shelf.
All my hardcore stuff hides under the shelf and day to day stuff just gets put on top. best part is the gap left is perfect to hold my clubs without rolling around
My install is coming along. I ditched the factory JBL sub and amp and have the two JL Audio's (500/1 and 300/4) in that slot behind the panel. Much cleaner than on the back of the seats. We may add a small fan that pushes the air out of the speaker grille in the panel that belongs with the factory sub.
Sub box is a low profile box that fits under the shelf and fires down.
Removable if required easily.
In short, Shelf stays, Stealth goes !!!
David
David
David
Here's a link to a similar thread -
https://www.yotatech.com/forums/show...ght=Stealthbox
BTW, I am aware there is a new audio forum on Yotatech. I posted in the main tech section because there are more users in here.
I see that the forum is breaking out interests into seperate sections. Does anyone else think Yotatech should be further divided by Model/Generation?
I have always noticed that Trucks & 4Runners were lumped together. Wouldn't it be better to seperate them even if they share common frames/parts? I would also like to see 1st gen/ 2nd gen/ 3rd gen/ 4th gen in the 4 Runners section. That way you could find more consolidated info on the generation you are interested in. Is it just me?
Janson
Originally Posted by keisur
you change your opinion if you had one. My wife's '03 came with one and it was really cool at first. now it sits in the closet in the guest bedroom because it was always in the way.
I'm very close to pulling the darn thing out entirely.
You're talking about the shelf, not the roll-up cover? I took the cover out on day one and it hasn't been back. The shelf, on the other hand, though super lame, just stays down all the time and doesn't really get in the way. But, I'd be happy to take it out for the JL sub.
The shelf is really a gimmick. The top shelf is too small and stuff falls off when I drive. The bottom shelf is too short -- about a shoe box will fit there. The space behind the shallow top shelf is too narrow.
yes the shelf. the cover is a good thing and easily removed and reinstalled. We tried just leaving that POS shelf in and down all the time but when we put both our mountain bikes in it I have to lower my seat since the shelf makes it about 2 inches to high to fit in there. so it's either break out the receiver hitch bike rack or lower my seat. The receiver rack isn't good when we plan on going shopping or something. so we just pulled the stupid thing and everything fits good and we don't loose any height from having that thing in there.
Originally Posted by RapidRunner
Beauty -- thanks for the reply -- whas it easy enough to get out? It doesn't leave anything looking messed-up or unfinished when it comes out, does it? Let me know, 'cuz maybe I'll just go ahead and yank it out. Then I can order the Husky mat and not worry about the sides hanging over the edge of it! Thanks.
keisur:
So the fact that the gap btw the seats and the shelf when up is perfect for hiding my GF's purse or a camera out of sight when I park downtown and the fact that it folds flat in 0.2 of a second if you need a flat load space is also lame.
Good, glad we cleared that up and glad thats the facts and not just someones opinion....
I will dump mine right now
Anyone wanna but one cheap
BTW, if you take it out, there is a small gap but the bolt holes are covered by a trim piece.
David
Originally I wanted the DD shelf, but listening to you guys I might pass.
I haven't heard anyone review the actual JL sub yet though....
Does it match?
Does it rattle?
Does it hit?
Can you mount a amp on the front of it? (the area that looks like shark gills - or is that some kind of vent/port?)
For those of you with the DD shelf, what is the height of this thing? Could I fit a 10" bazooka tube under it? I have one with a Kicker F 10" in it. If that didn't work, I originally thought about building a sub box under the shelf, but I think it is too small?
Thanks for any replies.
Does it match?
Does it rattle?
Does it hit?
Does it match?
Does it rattle?
Does it hit?
Does it match?
Does it rattle?
Does it hit?
* Match is acceptable (I have seen a gray one )
* The one I saw in a 3rd gen was heavy and solid (no rattles)
*Acceptable performance for a single ten. Bear in mind, a 10 in a sealed enclsoure will excell in accuracy and will be tight but will not go low or
hit really hard.
* No room for amp BUT amp can go behind it where factory amp/sub goes.
* I have a sub box being finished that goes under shelf. Sub has to fire down as not enough room for a 10 to be vertical. We mocked one up and it sounded really nice for what I want.
Will report when complete.
Overall, the Stealth boxes are very solid, perform well if not exceptional and look factory. I feel they are a little expensive for what you get.
David
Toys4parts
Sep 26, 2015 01:56 PM
larrys93pickup
Sep 17, 2015 07:05 PM
