Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
3rd gen 2001 speakers
Old Apr 15, 2007 | 07:23 PM
burtonboy4's Avatar
What size are the speakers in the front? and in the back?
Old Apr 15, 2007 | 07:26 PM
Elton's Avatar
6-1/2'' front and 4'' in the rear need custom spacers in the rear for a 5.25'' speakers
Old Apr 15, 2007 | 07:29 PM
burtonboy4's Avatar
do you have to make spacers for to fit 5.25's. or can you buy them. the speakers im lookin at are 5.25.
Old Apr 15, 2007 | 07:31 PM
burtonboy4's Avatar
and can you fit 6-1/2's in the front? someone told me they were 6.75's
Old Apr 15, 2007 | 07:45 PM
Elton's Avatar
for the fronts the speakers are glued in place but a razor blade and a little prying will fix that for rears you can ether make the plates your self or buy them but there like 10bucks for two and you need 2 on each side other wise the magnet on the speaker will hit the window heres a few pics of mine sorry i didint get a pic of the spacers for the rears there jbl gto series the fronts are amped the rears are not it took me about 10hours to install all the speakers as i ran new wires for the fronts for the amp and the speakers are 6-1/2'' for the front fits great and 5.25'' for the rear
Old Apr 15, 2007 | 08:37 PM
nieuwendyk-25's Avatar
The fronts are an odd size like 7", the rears are 4".
You can fit 6.5" in the front and 5.5" in the rear, and with a little patience you can fit 6.5's in the rear. I did it and it sounds great!!! These are Focals. I was going to add a subwoofer, I even wired it, but these speakers have great bass response. I decided I did not need the Sub. I made the brackets myself out of MDF, and I painted them black just to make it nicer looking. I did have to modify the door pocket slightly on the back door.
Here are some pics
These are 5.5" in the rear with a custom bracket. I didn't like them so the next picture is a 6.5" component in the rear.
If you want more pics of the modification let me know.
Old Apr 15, 2007 | 08:49 PM
Here are some of the fronts with a custom adapter bracket.
Old Apr 18, 2007 | 02:31 PM
DavidA's Avatar
Search here...there is a ton of information on mounting 5.25 and 6 in the rears with a custom spacer. I have posted it quite a bit.
I have components in both the front and rear doors of my 2002. Love them.
Old Apr 19, 2007 | 10:09 AM
Rock Slide's Avatar
Check out this website for speaker spacers and adapter plates:
http://mjmautoinnovations.com/
Great products and for the price can't be beat.
I installed 6.5"s in the front and 5.25"s in the rear.
For the front, I just did some small modification to the OEM brackets and got the aftermarket speakers to fit w/o problems.
For the rear, I had to install 1 adapter plate, 2 spacers and a thin felt strip on each door to move the speaker out far enough so the glass would not hit the magnet when it was rolled down. Oh and a couple rows of silicone were placed between the spacers for a "rattle free" install.
Puchased all from the web site above.
Old Apr 19, 2007 | 11:37 AM
Hey,
Any picks of the new install?? Also, I looked at your profile...did the sound deadening in the floor make a big difference. I have only done my doors.
Absolutely love the Roll Bar!!!
Old Jun 3, 2007 | 08:47 PM
daytraitors's Avatar
I don't know if anyone else has tried this, but I'm going to try using Lexan and a 4" bore to make my adapter. Any thoughts on this?
It's easy to cut, and it's cheap.
-d
Old Jun 3, 2007 | 09:50 PM
I would probably insulate it with something, as it might rattle...otherwise it should work fine. I used MDF for mine. Wear goggles when you cut it the lexan...it sucks to get it in your eye. Why a 4 inch bore?
Old Jun 4, 2007 | 06:07 AM
Rock Slide's Avatar
Originally Posted by nieuwendyk-25
Hey,
Wow, sorry I missed that question. It was a couple months back and for some reason, I just now saw it.
Well you've seen pics of the install. As far as the sound deadening goes, it did make a big difference doing the floor. Now I just have to find time to do the doors some day.
On a side note, I have not given up on the idea of adding an amp to my setup...just working on some new projects at this moment. Will get around to it later.
Old Jun 4, 2007 | 07:08 AM
I understand completely. I am trying to remodel two rooms at my office, build a house (with a builder), get my Jeep ready to go on vacation (will hopefully be towing it with the Sequoia), and deal with the kids.
mct75
Aug 22, 2016 01:24 PM
Swampwalker
Oct 12, 2015 09:49 AM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
