Smilies
Co-Founder/Administrator
That link takes me to the home page.
If you mean this
it works find and dandy.
Make sure your settings in your Control Panel are set to under "Edit Options"
If you set it to something else, weird stuff goes on.
I prefer the above setting.
If you mean this
it works find and dandy.Make sure your settings in your Control Panel are set to under "Edit Options"
Message Editor Interface
When posting messages to the forums or other members, there are three interface types available to you. The simplest of these is a simple text box, while the last is a fully-fledged WYSIWYG editor, which allows you to format your text as you want it and see the results immediately.
Depending upon the capabilities of your web browser, you may not be able to use all of these options. If you experience problems when posting messages, try switching to a different interface type.
Message Editor Interface:
From the drop down box use:
Standard Editor - Extra Formatting Controls
