your shock hoops
Old Oct 7, 2012 | 01:02 PM
RUSHTOY2's Avatar
your shock hoops
i'm getting idea's together to setup my shocks. planing on running shock hoops front and rear (probably custom made) the rears through the bed of my truck. if you've got pictures of your own or just some recommendations on how, or where to mount them id love to see and here them. just show off your shock hoop setups and
Old Oct 8, 2012 | 06:22 PM
RUSHTOY2's Avatar
no ones got anything???
Old Oct 10, 2012 | 05:49 AM
E-ROC's Avatar
Old Oct 10, 2012 | 02:46 PM
RUSHTOY2's Avatar
cool setup, always like the look of the upside down V shock setups. i see you have your proportioning valve load sensor shaft cut off, how do you brakes work with that??
Old Oct 10, 2012 | 05:20 PM
donomite49's Avatar
http://ttora.com/forum/forumdisplay.php?f=186
https://www.yotatech.com/forums/f88/...49/index2.html
https://www.yotatech.com/forums/f201...merica-257093/
there is lots of stuff about suspension.
i like the shock hoops in the fenderwell, shocks between the frame and tire, without invading the bed.
http://www.trailslesstraveled.com/ar...ar-suspension/
http://ttora.com/forum/showthread.php?t=6189
http://www.4crawler.com/4x4/4R_suspe...l#Update-part2
http://www.pirate4x4.com/forum/toyot...faq-2-0-a.html
Old Oct 10, 2012 | 06:40 PM
E-ROC's Avatar
i'm going to zip tie the rod in the up position for best rear braking. always done it and has been good for me. simple and functional.
Old Oct 11, 2012 | 04:43 AM
RUSHTOY2's Avatar
gotcha, i'm just trying to come up with ways to deal with mine on this build. ill probably try this out and if it doesnt work ill just buy the manual one....
Old Oct 23, 2012 | 09:44 AM
oldgold3vze's Avatar
You might as well just remove the LSPV and return line and run a single line to the rear brakes, the zip tie sounds janky. As for hoops and shocks, go as big and as long as you can. It's a bummer to try and set em up so they just barely miss bottoming or topping out. Here are some easy front hoops I bent up. 1.75", 5.5" CLR die. I could easily mount some coil over shocks to these if I ever go links.
As for the rear, whatever you do, do NOT go the A-frame route. The dampers need to be as close to inline with the axle movement path as possible. Try and mimick the stock rear location, just extend the mounts.
Old Oct 23, 2012 | 04:01 PM
RUSHTOY2's Avatar
thanks for the info, i was planning on probably going the same route as you on the front setup, and never considered that A-frame setup in the rear
Old Oct 24, 2012 | 07:44 AM
Robert m's Avatar
front
rear
Old Oct 24, 2012 | 07:59 AM
RUSHTOY2's Avatar
i really like your rear setup but with the front reservoirs mounted right over the engine wouldnt that make them really hot and thats what you don't want....????
Old Oct 24, 2012 | 08:09 AM
Robert m's Avatar
they have been like that for over 3 years now with many desert trips in summer temps and i havent had a single issue with the heat. they do get hot, but not over heating hot. i have though about moving them down to the shock hoops but just havent had a reason to yet.
Old Oct 24, 2012 | 08:16 AM
RUSHTOY2's Avatar
gotcha, well if it works it works. no need to fix somthing that ain't broke
Old Nov 2, 2012 | 03:35 PM
moltenone's Avatar
Wow thats some serious engineering going on there,looks awesome.
Mark
Old Nov 14, 2012 | 02:53 PM
These probably don't count but... Here's my '89...
And here's the race truck which is an '04.
bare
full
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
