Toyota CV joint... High angle vs Low angel???
Old Dec 1, 2005 | 05:20 AM
gmrwizard's Avatar
This has been my original post on other forums. I am expanding my searches.
How do I identify a toyota high angle cv and a low angle cv?
What years and what aplications (front/rear) do I look or ask for?
Are there tell tale shapes, dimples, notches, etc. I can look for?
Need to find a couple high angle cv's to use for the rear of a two piece shaft and a spare.
OK,
here is the newest brain storm (number 6, I think). Dave (at Marlin Crawler) and I came up with this idea.
I need a carrier flange off of a turbo drive shaft. They are bigger diameter. I then should be able to drill out the bolt holes in a v6 front shaft CV, mod for increased flex, and run it for a rear. Should work.
Anybody know where I can find a flange?
Anybody done a two piece to one piece conversion?
Old Dec 1, 2005 | 06:36 PM
gmrwizard's Avatar
New intel. Don't think the "turbo" plan will work. But we are pretty sure a Taco 4x4, 2.7L x-cab driveline has the flange I need.
Anybody got one of those?
Old Dec 2, 2005 | 06:54 AM
Napoleon047's Avatar
http://www.4x4wire.com/toyota/tech/cvmod/
why do you need the CV in the rear? how much lift are you running? i had to modify my IFS CV to re-use it up front with my square driveshaft, but its sitting at a rather steep angle.
Old Dec 2, 2005 | 07:29 AM
gmrwizard's Avatar
Long story:
Building a 7s racer and I am not running the front axle in this truck, I pulled all that extra weight out along with the trany. I installed a 2wd R150 trany. But I am not real happy with the "slip yoke" driveline at the trany with all the flex angle of 16 inches of rear end travel. I feel it would wipe out the bushing at the back of the trany so I beat this by making a 9" long (the difference in length of the transfer case) front half of a 2 piece drive line to run 0 degree angle out of the trany. The CV joint will then do all the work.
Old Dec 5, 2005 | 05:14 AM
gmrwizard's Avatar
bump to top
Old Dec 7, 2005 | 05:04 AM
gmrwizard's Avatar
OK Taco flange idea a bust. Still have one more slim chance on a part that might work, really doubt it will but hey, keep fingers crossed.
Meanwhile need to start looking for a complete V6 Taco rear two piece diveline. Y'all know where I can find one?
Old Dec 7, 2005 | 09:12 AM
if you have the cash, i would call up high angle driveline and have a talk with jesse rather than try to rig something up for your rear driveline, especially if its in a race application.
Old Dec 7, 2005 | 11:15 AM
leiniesred's Avatar
how much weaker is the 83 CV?
If anyone has broken one, maybe I'll take apart my 85 and the 83 CV shafts and put the bigger center shaft and flange pattern on my round rear driveshaft and leave the smaller stuff on my spare Square Driveshaft.
Old Dec 11, 2005 | 07:07 AM
gmrwizard's Avatar
Trying to do "off the shelf" parts. Makes it easier to find replacement parts in the future.
Old Jun 25, 2011 | 09:51 AM
Mark Geletzke's Avatar
85 toy cv problem
Try not to hate me for having a samurai. Here's what I'm doing. Bought an 85 toy front cv driveshaft from Cal Mini Dismantlers. Only one they had. I got it home, took it apart to replacing u joints and cv ball. When I got it apart the spring was missing, the centering pin was oval and useless. Started this project to eliminate drive line vibration in the rear of zuk running non offset housing from sidekick. Sami has been lengthened 4" trying to retain turning ability. Running yj 2 1/2" lift soa. Out of work now and have to do on the cheap right now. Since sidekick rear end is centered diff like Toyota I figured with cv mods taken from 4x4wire I could get rid of vibration. I've gone this route as local driveline shops say they got nothing for me. I'm very mechanical and if I can do it myself I will. Always looking for a better way. Ok so here's where the problem comes from. This was the only high angle toy cv they had. So now I have to replace centering ball flange. Measured cv center to center as I know there's a diff between 79/83 and 84/85. Mines a little over 3". Ok I order from Rock Auto large diameter ball rebuild kit, no prob there. Ball locating flange different story. Right pin length, wrong bolt pattern and machined too thin for my liking where the pin sets. They offered two with the same dementions but no years to identify so I took a gamble and bought it. So here's what I need to know. Are later years 86 and up the long H or short H. Reason being cal mini truck said they'd help me, but I'm going in a little blind as all my knowlage is in Suzuki. Can someone help me get what I need plz.
Thank you,
Mark
wberry85
Jul 6, 2015 03:24 AM
zytra
Jun 24, 2015 08:14 AM
saphirekosmos
Jun 22, 2015 10:26 AM
Mr.Black
Jun 21, 2015 10:17 AM
peterbilt
11
Jun 19, 2002 10:56 AM
