Old Mar 11, 2016, 02:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Toyospearo's FLATBED build...
Old Dec 29, 2010 | 02:08 PM
  #181
toyospearo's Avatar
I appreciate the comments!
The flatbed is about to be pulled off, lightly sanded and painted again with an industrial paint. I am also separating the bed and having it Line X'ed.
Pics soon!
Old Mar 10, 2011 | 08:28 AM
  #182
Moabite89's Avatar
Wow, im very jealous of the bed. You do awesome work man.
Old Apr 20, 2011 | 01:25 PM
  #183
engineshoppa's Avatar
What is the overall diameter of your tires. They look proportional to the truck. Exceptional truck!
Old Apr 20, 2011 | 01:36 PM
  #184
toyospearo's Avatar
THanks for the compliments!
The tires are 32 10.50 15's
Next tire go around I think I might go up to 33's. There is not a huge difference between 32 and 33. At least not the TSL Swampers I have seen.
Old Apr 20, 2011 | 02:54 PM
  #185
Thank you for the info. I think I am going to go with 16's for more future tire selections.
Just picked up fenders for the truck today. Bodywork starts! The box is toast and as I posted before flat bed is in the plans.
Have a good one!
Old May 16, 2011 | 03:01 PM
  #186
davecop4x4's Avatar
Sic work bro that is one of the best flat bed jobs ive ever seen!
Old May 16, 2011 | 03:08 PM
  #187
toyospearo's Avatar
Thanks!
The bed is getting a facelift this week in addition to new carpet. I'll post up a few pics when I get it done.
Old May 17, 2011 | 08:42 AM
  #188
kivetts04dmax's Avatar
so how much did this all run you to make? I don't even have a Toyota yet and I already want to start this project!!
Old May 17, 2011 | 10:11 AM
  #189
toyospearo's Avatar
Can't remember.
I think somewhere back in this thread is the cost.
Old Jun 27, 2011 | 06:34 PM
  #190
latrans's Avatar
Your build is absolutely amazing! My wife seems to be annoyed with the time I am spending studying it. How wide did you make the front end (near the headache rack) in comparison to the cab?
Old Jun 27, 2011 | 06:40 PM
  #191
toyospearo's Avatar
Thanks for the compliment and I hope this thread doesn't get you into trouble with your wife!
I can't recall exactly how wide I made it. I think it is the same width as the cab if I remember correctly.
I did just sand and add a fresh coat of paint to the flatbed and I will get some pics up of what it looks like.
Old Jun 28, 2011 | 06:02 AM
  #192
latrans's Avatar
You said, "My rig is a trail rig more than a rock crawler. I designed it with this in mind. I am aware of the flex, clearance and cargo issues." What are these flex, clearance and cargo issues? I just bought an 85 SR5 off my younger brother and am wanting to flat bed it. Are these things I should be worried about? Thanks!
Old Jun 28, 2011 | 06:09 AM
  #193
xxxtreme22r's Avatar
Any time you flatbed a truck you loose alot of the uptravel capability of the rear tires. Especially if running anything bigger then a factory tire. You either have to raise the deck of the bed or notch it out and make fenderwells. Pros and cons to each method. With raising the deck of the bed, it ends up kinda high to load stuff in, if notching it out, then you loose that area to load flat stuff in.
Old Jun 28, 2011 | 06:14 AM
  #194
latrans's Avatar
What about the flex? Where does the problem lie here?
Old Jun 28, 2011 | 06:16 AM
  #195
The flatbed if not high enough or notched out enough will not allow uptravel and the tires will hit the bed alot sooner then the bump stops will hit. This is not a problem with most street driven trucks. But it becomes an issue with anything that might see off-road. And in some cases downward droop travel can be affected as well since the other sides tire tilts as the other side goes down. But that's isn't as much of an issue as the up travel clearance.
Old Jun 28, 2011 | 07:31 AM
  #196
toyospearo's Avatar
Xtreme is correct. However, I have not had any flex issues. I wheel this rig pretty hard. Mostly hunting and bouncing around old logging roads. I do get into a rock or boulder field from time to time and I have not had any issue with flex.
I will say if I did a bit more extreme rock crawling I could see where I might have an issue in the rear but this truck was not built with that in mind.
Hope that helps.
Old Jun 28, 2011 | 07:44 AM
  #197
I haven't had any issues with mine as well. It's just something to watch out for when converting to any type of flatbed. All-Pro's not including.
Full uptravel, it doesn't stuff any higher then this due to bump stop. If I were running 35's, I'd have issues.
Old Jun 28, 2011 | 10:50 AM
  #198
latrans's Avatar
Right on. Thanks for the help. One other question, if I may...where do you guys get the lights for the back end? This has been my main problem designing my flatbed. Also, what lights are required by law? Thanks again!
Old Jun 28, 2011 | 10:56 AM
  #199
Laws vary by state, might wanna Google up your local DMV website. I don't know about toyospearo, but all mine are are 4" tractor trailer type lights and some 2" ones thrown in. The tractor trailer type clearance lights in the corners. The 4" lights you can get the push in grommet style or the screw in types. I have both on mine. The screw in ones are more secure and less prone to theft.
Old Jun 28, 2011 | 02:25 PM
  #200
toyospearo's Avatar
I got my lights at superbright led's
They are dot approved
