stupid sas question
Old Nov 20, 2007 | 07:46 AM
cherokeechief79's Avatar
stupid sas question
ill be doing this soon.before i start removing the ifs dont i have to remove the tbars?do i just losten the rear bolts on them?will they drop out when the ifs stuff drops or do you take them out first?
Old Nov 20, 2007 | 12:44 PM
blazerboy72's Avatar
I disconnected mine at both ends but left them in the truck until after the ifs was removed. As long as you take the presure off of theM iDont see why it would matter when you remove them.
Old Nov 20, 2007 | 03:58 PM
Napoleon047's Avatar
as long as you release the tension before you unbolt the upper a-arm or cut its mounts, you are ok.
Old Nov 20, 2007 | 06:26 PM
Elvota's Avatar
You need to relieve the tension on your T-bars before you start taking to many things apart. Don't want them to unload when you least expect it.
Old Nov 20, 2007 | 06:41 PM
UKMyers's Avatar
Torch em half!!!
Old Nov 24, 2007 | 07:59 AM
Adam F's Avatar
Originally Posted by UKMyers
Torch em half!!!:
Yup! Just torch everything thats in the way. Once its jacked up and the wheels are hanging, all the spring tension is releived so your free to cut them up at will.
Old Nov 25, 2007 | 04:43 PM
dirtoyboy's Avatar
If you can't get your torsion bars off, you have NO BUSINESS doing a SAS
Flying91
45
Apr 11, 2024 04:39 PM
westonian18
May 1, 2020 06:38 AM
Shagool22
Aug 14, 2015 12:24 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
sabine
Jul 18, 2015 03:59 PM
