one more stupid sas question
Old Nov 20, 2007 | 04:40 PM
cherokeechief79's Avatar
im using skys front kit.it comes with the templates for the hole thru the frame mounts.if im going to have to do this with a hole saw would i first try to get a small hole thru the center of the large hole in the templates on both the outside and inside of the frame?once i had the small holes would i go thru the outside of the frame from the outside and the inside of the frame from the inside.is there enough room to get a holesaw thru from the inside of the frame?i know there is some ribbing inside ill have to tacke one way or another.
Old Nov 20, 2007 | 06:24 PM
Elvota's Avatar
A pilot hole is probably a good idea. If you can get the pilot hole drilled from the inside, then my bet is your hole saw will work from there as well.
If you can barely get the hole drilled on the inside, it could still help. Just drill the entire hole from the outside. Once through the frame, and then the webbing inside... your pilot hole would help you stay lined up.
Get a few extra pilot bits for your saw. I have heard it's very easy to break them when you a dealing with the webbing inside.
If you know someone local skilled with a plasma, you can drive the truck over there and have them cut the holes before you ever start removing any of the IFS stuff.
Old Nov 20, 2007 | 09:06 PM
customcruiser's Avatar
torch a hole, you are gonna need a torch anyways to cut all that ifs crap off otherwise its gonna take forever
I almost broke my arm many times with that damn hole saw.... hole saw is a BITCH
Old Nov 20, 2007 | 09:13 PM
Justinvd's Avatar
Yeah i saw a really high power industrial drill catch while holesawing and it flipped my freinds dad right over. Go super super slow if you do the holesaw and pilot hole is a must
Old Nov 20, 2007 | 09:35 PM
I actually tied the drill to my sliders (drill had a handle that screwed onto the top)
but it was still a BITCH
Old Nov 21, 2007 | 01:21 AM
Blizzard's Avatar
Use plasma... Easy and fast!
David
Old Nov 26, 2007 | 05:33 PM
dirtoyboy's Avatar
i did my whole sas with basic tools...u dont need a plasma or torch...
pick up some high quality cut off wheels from an industrial tool shop
I think a hole saw makes a cleaner cut than a torch anyways
I DID however rent a right angle drill just for this job and it was a piece of cake
Old Nov 27, 2007 | 02:40 AM
thanks for all of the replies!
Flying91
45
Apr 11, 2024 04:39 PM
westonian18
May 1, 2020 06:38 AM
Shagool22
Aug 14, 2015 12:24 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
sabine
Jul 18, 2015 03:59 PM
