Speed Sensor after SAS
I just finished the SAS and may check engine light came on. I found out the code was PO500 which is malfunctioning speed sensor. I no longer have any speed sensors so it makes sense; however did non abs 4runners have the sensor on the transmission? Does anybody know what parts I need to convert it so I have a speedometer and no check engine light?
37x12.50's and they look small. I think I'm going to switch from Rancho 44044 spring to stock waggy springs so hopefully it will drop about 2-3". It ended up higher than I wanted it.
Originally Posted by NorCalVP
I thought that the speed sensor was on the T-case?? I don't think that there is anything on the front suspension.
http://www.sonoransteel.com/4runner.html
If you have abs there is a sensor at each wheel.
Yes, there is an ABS sensor at each wheel, but i think the speed sensor is on the T-case... With your ABS sensors removed, you should get an ABS light, not a check engine.
speed sensor is indeed on the T-case, ABS or NON ABS. It is always on the T-case. Maybe your sensor itself has gone out.
When I did my conversion I had to get a speed sensor out of a 4WD since my 2WD sensor would not fit. Cost me maybe $20 from a junk yard.
I finally found out that there were a few 4runners produced which had no speed sensor on the transfer case, mine is one of those. I have called a few dealers and when they enter my vin # no speed sensor comes up. I decided to extend the rear speed sensor lines, to see if it helped and my speedometer works and no more check engine light. The speedo is just off by quite a bit since it is measuring tire speed not gear speed.
montanatruck
Feb 26, 2017 07:07 AM
Backcountry411
Jul 24, 2015 08:06 AM
