SCBA Bottle for tire fill
Im a volunteer firefighter and my department got new air packs a little over a year ago. I realized the other day that we still had all of our old packs and bottles. I'm wondering if I can use this old bottle to fill my tires. What do you guys think? The bottle is still in perfect working order so I'm not worried about any safty issues in that regard. It's rated for 2216 P.S.I. Any input yall can give me would be great thanks!
I would not use it...Just send it my way and I'll take care of it for you. I'd hate to see someone get hurt.
They should be good to use, Great find!!! before you find someone to fill them you may have to get them pressure tested.
Has been done, but filling the tanks can be difficult unless you have someplace that will do it for you.
I know of one guy doing this on one of the Caribbean islands. He works at a resort with a dive and boat service for the guests. Since he needs to air his tires down and up many times a day and always has Scuba tanks around, it is an obvious solution for him. He runs one of my 4Air hoses:
- http://www.4crawler.com/4x4/ForSale/4air.shtml
which we set up with a Scuba quick disconnect fitting he supplied.
Man, that thing is an antique!!! Do you have the scba threads to tire chuck adapters? If so, lemme know where to find em, I know we have old bottles laying around at work too. And as long as that thing had a recent hydro, I say give it a go. Now you just have to grab an old bracket so you can mount it somewhere cool.........
That's the problem I'm not sure what all I need in order to hook up an air hose and what not.
I plan on mounting it to the rear rollbar (out of a first gen) I put in my 3rd gen.
Someone gave me this info on another forum:
"it's doable but it doesn't have enough volume to fill tires as gas(air) is stored in the tank as vapor, on the other hand, the popular CO2 tanks, gas(co2) is stored as liquid, the volume is plentyful.
i use the samilar scott airpak for my air guns only it's a carbon tank holding 4500 psi. you will need a special adapter(~$130) to get air out of the tank, then a welding gas regulator to reduce the output pressure under 100psi to safely operate with common air hose/tire filler. all has to be made from stainless/brass fittings.
IMHO, it's just not worth the hassle. "
Yes, not quite the volume of say a CO2 tank. I think a typical Scuba tank is like 80 cu.ft. so you could get about 6 fillups of 4 tires from say 15-30 psi:
- http://www.4crawler.com/4x4/CheapTri...uchAirForTires
To heck with illegal - just downright DANGEROUS.
Did you see the mythbusters where they launched a bottle through a concrete wall?
x2 on the gas storage vs liquid for CO2. I think that is more like a 20 CF tank (thinking of my welding Ar/CO2 which doesn't compress to liquid either), so you're looking at maybe ONE fillup of your 4 tires.
Hey dude,
You should have asked me, I tried this about 3 months ago with the old tanks from CFD and it's a no-go.
Too dangerous and not worth the hassle.
My uncle has a newer tank that's rated around 4000psi, IIRC, that I may try it with but with the extra crap needed to make it usable it's not worth it IMO.
I'll just get a Powertank one of these days.
Runner is looking good though, man.
I'll be getting the '85 back tomorrow and new suspension on at the end of the month - you'll have to check her out when she's done.
Fink
Fink
Tacoma1313
Aug 17, 2015 05:44 PM
mr_manny
Jul 31, 2015 10:39 AM
