Round Three: Project Overdose
Old Oct 16, 2008 | 01:33 PM
  #61
86Crawler's Avatar
Nice rig. Love the build. Im subscribed.
Old Oct 16, 2008 | 02:34 PM
  #62
86Crawler's Avatar
Do they have those tires in a smaller size
Old Oct 16, 2008 | 02:43 PM
  #63
88wildrunner's Avatar
Originally Posted by ScottyC
They are $185/tire + shipping which is pretty damn reasonable depending on the zip code.
Where did you order them from, i priced them at a local shop and they want around $220 a tire
Old Oct 16, 2008 | 03:49 PM
  #64
ScottyC's Avatar
My account. That is the price for anyone who wants a set.
Old Oct 16, 2008 | 08:44 PM
  #65
how much would the shipping of 4 tires cost to 95722?
Old Oct 16, 2008 | 08:55 PM
  #66
ScottyC's Avatar
$830 shipped to your door for four 35s.
Old Oct 20, 2008 | 02:57 PM
  #67
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
How much for a set in 31 10.5 15's? Or the A/T's?
Old Oct 27, 2008 | 05:06 PM
  #68
ScottyC's Avatar
Duals and R151 Turbo tranny are in now. I managed to use a few center console parts from a 90' 4runner to get this done along with re-using the intermediate console section from my stock setup. I used the front shifter boot setup, and a rear heater center console from the 90' V6/5spd 4runner. I was able to retain the rear heater, and the twin sticks really help with not have to deal with moving the factory rear window switches and wiper as well.
I modified the 90' V6 shifter slightly to work, and then used a forward shift shifter base with the 88' stick on the front Tcase. The original forward shift shift was hitting the dash/stereo.
IMO, this turned out much better than I thought it would. It actually was a pretty clean install considering the mutt of parts used to do this.
Old Oct 27, 2008 | 05:13 PM
  #69
Hayes's Avatar
Do you have any pictures of how you mounted the center console? I just bought that exact console and can't figure out how to mount it into mine.
Old Oct 28, 2008 | 05:33 AM
  #70
ScottyC's Avatar
It bolts right to the top of the rear heater. Do you have the rear heater?
Old Oct 28, 2008 | 08:19 AM
  #71
Hayes's Avatar
ah, that I do not... looks like I will be making a bracket for that.
Old Oct 28, 2008 | 02:38 PM
  #72
ScottyC's Avatar
You need the standard arm rest console then.
Old Oct 28, 2008 | 02:41 PM
  #73
Hayes's Avatar
not really, the only difference is where it mounts up. I can make a bracket to adapt the bolt holes...
Old Oct 28, 2008 | 02:44 PM
  #74
ScottyC's Avatar
If mine didn't have the rear heater I would run the standard arm rest console. It give A LOT more storage space.
Old Oct 28, 2008 | 02:46 PM
  #75
Hayes's Avatar
I'm not really looking for storage space but the higher armrest...
Old Oct 28, 2008 | 02:54 PM
  #76
ScottyC's Avatar
I understand.
Old Oct 29, 2008 | 03:00 PM
  #77
ScottyC's Avatar
90' 4runner center console
Rear pinion angle is money $$$
Built the front CV shaft myself. I noticed no runout and no vibes on the shaft up to 65mph.
Overall interior
Old Oct 29, 2008 | 05:45 PM
  #78
DIRTCO's Avatar
Did you have to move the rear heater assy. itself or the heater hoses?
I noticed that you added spacers to the crossmember, was this to clear the hoses? Did you use the stock bolts that came with the crossmember and where did you pick up the spacers? Do you have a body lift?
Sorry for all the questions, but I want to keep my rear heater when I install my dual cases. I don't have a body lift and I'm not going to run one. I looked under the vehicle and the hoses look close, but I think I can get around that. My main concern is the rear shifter / rear heater clearance.
Old Oct 29, 2008 | 06:04 PM
  #79
ScottyC's Avatar
No body lift, and yes, the spacers are there for the clearance. They are 3/8" spacers that come with some of the Trail-Gear kits for the rear shackles. I have a bunch of leftovers that were sent to me for various installs, so I decided to try them to help clear. I have a little more than an inch of clearance with the rear CV shaft.
The 4cyl motors do sit about 2.5-3" further back, so the center console could be an issue, but I have seen guys that have been able to retain them with duals and the 22R design.
I know that the A/T is shorter than the R151, so if you are keeping the A/T and going with an inchworm dual setup then you might be okay.
Old Oct 29, 2008 | 06:22 PM
  #80
scuba's Avatar
nice build !!!
keep up the good work
