Removable 1st gen doors?
Old Apr 26, 2006 | 07:58 AM
marty4runner's Avatar
Hello to all-
I took the doors off my 88 4Runner the other day. It was pretty easy, but I want easier. I thought about grinding out and removing the hinge pin and replacing it with a big bolt with a cotter pin on one end for quick removal. My worries about that method is fitment. I don't want the door to rattle too much when on an I don't want it to "tilt" when I open the door (know what I mean?). Another method I thought of is fabbing some Jeep-like exterior hinges. If anyone has taken off a Jeeps doors, you know how easy that is. So...I'm sure theres another thread about this somewhere, I just can't find it. Does anyone have suggestions, pictures, things to look out for, etc.? Thanks!
-Marty
Old Apr 26, 2006 | 09:09 AM
waskillywabbit's Avatar
Easy on, easy off.
Old Apr 26, 2006 | 09:12 AM
1985 4Runner's Avatar
WabFab to the rescue....you need some theme music!
Old Apr 26, 2006 | 10:12 AM
i dont get it
I see what you've done to the hinges in the picture (opened up the upper mounting hole and replaced the hinge pin with a bolt), but I guess I don't see how that helps. Of course, the bolt hinge is a good idea, but if that is the part you remove, are there problems with rattling, etc? What do you do with the cut-open upper hinge mount?
-Marty
Oh, do you only put in the upper bolts on the hinge mount, then you only have to loosen them a little (or not at all if you don't completely tighten them in the first place) and lift the door up out of the half-holes. Cool! If that's what happens there, I think I'll try it. Good job!
Old Apr 7, 2007 | 10:42 AM
Sonofmayhem's Avatar
bump for the answer?
Old Apr 7, 2007 | 11:29 AM
http://www.4xinnovations.com/pages/g...g/hingekit.htm
Old Apr 8, 2007 | 09:27 AM
nope had those and they wouldnt cooperate for me. I actually got so mad i sold them.
Old Apr 8, 2007 | 10:16 AM
Hayes's Avatar
Originally Posted by waskillywabbit
I don't get the point of cutting the upper hole...
Old Apr 9, 2007 | 09:19 AM
Volcom's Avatar
You leave the top bolts slightly threaded in the door and place the door onto the hinges. Take your nice shiny 12mm ratchet wrench and tighten them up. I have the same on my 84 4Runner. Take about 20 seconds to take them off and maybe 45 seconds to a minute to get them on. I don't run the bottom bolts, just the top two.
Old Apr 9, 2007 | 09:40 AM
Yota Tony's Avatar
Just cut the hinge pins.
I plan to do that with my 82.
Old Apr 9, 2007 | 09:44 AM
drew303's Avatar
What do you guys do about mirrors? Its illegal where i live to run without atleast a driver side mirror. Had a buddy get ticketed for having his yota doors off because no mirrors.
Old Apr 9, 2007 | 10:44 AM
lofreqjeff's Avatar
I made mirror brackets for my tube door and I bought some trailer mirrors from Pep Boys:
Jun 1, 2021 01:51 PM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
