Recovery Points Anyone?
Old Jan 4, 2010 | 03:42 PM
VSU_4runnin's Avatar
Well as usual I was bored today and decided to finally do something with my new welder. So I went down to northern tool and bought some 1/2" D-rings and finally made myself some front recovery points. (about time after the last time when we had to use my lower A-arm)
well first things first removed that waste of metal brush guard
Looks so weird to me
next removed the bumper: Detailed Writeup
Point of clarification
This mount has 2 screws, one vertical one, and one horizontal one with the head pointing to the rear of the vehicle, I sugguest removing the horizontal screw, the vertical one was very hard to get the bumper tabs off.
Bumper off, and endcaps sanded, cleaned, and re welded for strength
looks good
final product
Close up
Also had to trim the lower plastic part of the bumper to expose the d-rings, I will put that picture up tomorrow.
Temporary solution, hopefully a new bumper is in my next 2 months future
Old Jan 4, 2010 | 03:51 PM
waskillywabbit's Avatar
I hate flux core...always makes a mess.
Looks good.
Old Jan 4, 2010 | 05:12 PM
thanks alot wabbit, ill probably be coming to you for that bumper order.
Flux is doing the job for me right now, but ill be getting the mig setup attachment here in a few weeks, dad wants a t-top for the boat
Old Jan 4, 2010 | 05:19 PM
MuddfreaksOffroad's Avatar
how much load do you think that weld will hold? thats my only question i would of mounted them on the bottom part where you see most toe hooks are. lol my thoughts only tho
Old Jan 4, 2010 | 05:49 PM
well the endcap should fail long before the welds do. as far as mounting them, steel and welds can usually take more tension (outward pull) than shear force. if they were mounted to the bottom they would be a. harder to get to in a muddy recovery situation, and b they would experience that lateral shear which would compromise the welds i believe
Old Jan 4, 2010 | 06:46 PM
tc's Avatar
tc
Did you weld the end caps on?
You DO know, they just pull out, right?
Old Jan 4, 2010 | 06:51 PM
of course, welded all 4 sides and put an extra support bracket on. ive also tested it out and they are holding beautifully.
Old Jan 5, 2010 | 09:40 AM
oh lol well see i dont konw much bout welding for now. but id honestly not put them there lol but thats me lol
Old Jan 7, 2010 | 09:43 AM
crolison's Avatar
Mines kinda near the same way, but i have a 2x2 running between the frames, which is also a bumper mount.
Old Jan 7, 2010 | 11:52 PM
wyoming9's Avatar
Red face
Why did you get bolt on D rings if you were going to weld them??
I also don`t like where you put them but it is your vehicle .
If i had to get someone out of some place in mud I will attach to the lowest point i can get.
Old Jan 8, 2010 | 08:13 AM
1. those were the only ones available
2. they are in the lowest place on my vehicle, the suspension is the only part lower?
Old Jan 11, 2010 | 01:23 PM
pillguy's Avatar
Its a great idea what you did, but I hate to say, you are going to pull those right out even with welding them on as you did.
Just look at the tow points and tie down on the frame, they are frame plated from the inside.
Another thing, although I am no expert, you would get better grounding if you grounded the frame itself rather than the tow ring.
I would rethink your tow points to at least the brace the other person showed on the post.
1/8" is not going to support your tow points.
Old Jan 11, 2010 | 02:12 PM
4banginRunner's Avatar
You really trust those welds and attachment point with the forces that it could be subjected to it?
Old Jan 11, 2010 | 02:57 PM
WatsonToyota's Avatar
just wrap a chain around the radiator...jk
How have you "tested it out"?
Old Jan 11, 2010 | 06:28 PM
tested it out the other day by sinking it in a sandy muddy hole and got snatched out. worked great, no bends no cracks theyre as strong as ever
and alot of welders are picky they will only function if there is a good connection so the ring made a good ground for what i was doing
buckz6319
Aug 5, 2017 03:50 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Obmi
Oct 4, 2015 11:30 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
