Project: Save The Yota!
Old Aug 14, 2012 | 06:17 PM
  #121
Redeth005's Avatar
Omg i began to look through your thread. i was all into it, And seen you hack it all up and my first thought was NOOOOOOO! then i got into the finished product and i was like All right.... all right.... Came out freekin' sweet! then i came accross the burnt engine and i was like GASP!!!! nooooooooo. wtf..... sorry to see all your hard work go torn apart. i feel for ya man. But Judging from all the pix of the work you done im sure you will be able to get a new rig fixed up just as good.
Old Aug 15, 2013 | 04:33 PM
  #122
absalom's Avatar
Whatever happened to your TDI swap in that 4runner??
Old Sep 25, 2013 | 06:12 PM
  #123
Hardstripe's Avatar
Well I have been going to school to be a diesel & heavy equipment technician- and working in a couple shops. I did get it in there, but I took it out to rebuild it- good thing I did because it had stuck rings on 3 pistons. I upgraded the hell out of the engine, with a stage 2 cam, rosten rods, new bearings and rings, pp762 injectors from kerma, a chip tune, an 11mm pump, a vnt turbo upgrade that puts out 24 psi, straight pipe exhaust, a huge front mount intercooler, a new aluminum radiator, and a few other little goodies. I chopped the top and welded on a top with a sunroof, bobbed the bed, had my buddy help me bob the topper to match, and welded in fish plates for the new motormounts to reinforce the frame. I am working on making new motormounts hopefully tomarrow, and the engine will be going back in. I need to purchase a good donaldson air filter, re-do some plumbing and wiring, and start doing body work and paint. I am considering a divorced overdrive unit for freeway use- wont work in 4wd, but it will allow me to split every gear and achieve much higher freeway speeds, and better fuel economy. I have a ton of pics.. been tinkering on it here and there... but just havent been able to put any serious time in to it. I havent given up though, I am hoping to get it done this fall. Should h ave about 200 hp and 400 ftlbs, and still get like 30-35 mpg
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
shredder4286
Oct 1, 2015 01:09 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
tylermx71
Sep 29, 2015 08:49 PM
