Pitman arm clearance???
Old Jul 22, 2006 | 07:57 PM
  #41
Marc P's Avatar
I am running Allpro/hybrid springs...about 1.5 inches fwd. I would move my steering box if I need more than 3/4 inch difference to clear. I may move it and brace it later if I decide to run bigger tires or change the configuration.
For now though, I will replace the pitman arm.
Old Jul 23, 2006 | 08:18 PM
  #42
Marc P's Avatar
My 2wd pitman arm was not even close to fitting...the hole with splines was too small.....
I guess I will call Sky tomorrow...anyone else make a 3/4 drop pitman other than Sky and OTT??
Old Jul 24, 2006 | 06:51 AM
  #43
Robinhood150's Avatar
Finally took the truck out to the trail and I don't seem have any pitman arm problems. It doesn't look like it from the pictures, but the bumpstops really help.
Both TG and Marlin say bumpstops (and the extensions) must be used or the warranty is void for the springs.
Old Jul 24, 2006 | 06:14 PM
  #44
ecchamberlin's Avatar
YOu know I am no expert on this SAS stuff but could you also get the 2wd steering box and swap it in? Wouldn't the spline issue be solved?
Or is the gear box totally diff for a 2wd and not strong enough?
Old Jul 24, 2006 | 06:55 PM
  #45
Marc P's Avatar
Problem solved....ordered the Sky pitman arm today
Old Jul 24, 2006 | 07:56 PM
  #46
Billet is so purdy!
Old Jul 25, 2006 | 09:30 AM
  #47
rockota's Avatar
2wd box bolts on w/ 2 mounts, IIRC, instead of 3.
Old Jul 25, 2006 | 10:04 AM
  #48
deathrunner's Avatar
NICE!
Old Aug 10, 2006 | 06:40 PM
  #49
Marc P's Avatar
My pitman arm clearance is no longer an issue....
It is close, but does not hit
Old Mar 30, 2007 | 07:57 AM
  #50
waskillywabbit's Avatar
Why not just use a flat Pitman arm as opposed to just a shorter one?
Old Mar 31, 2007 | 09:47 PM
  #51
Marc P's Avatar
With a flat pitman you would still need need to move the steering box, otherwise the pitman will not clear the frame.
ladybugRC
458
Aug 21, 2020 10:41 AM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Project90
Sep 24, 2015 11:40 PM
