PICS- Swapping battery and airbox.
Old Sep 22, 2010 | 06:07 PM
  #41
Duffdog's Avatar
You would want the vafm door to stay level. If it is tilted, then going over any bumps would cause it to open and close, perhaps causing a lean and then rich condition and...less power.
Old Nov 13, 2011 | 04:59 AM
  #42
808nickh's Avatar
Finally got my Supra AFM those are not very easy to find, just have to gather a few more parts and mine will be next
Old Nov 14, 2011 | 11:46 AM
  #43
Gone_in_9sec's Avatar
Why do you need a supra afm?
Old Nov 14, 2011 | 04:29 PM
  #44
angrydogtattoo's Avatar
Supra AFM provides better performance
Old Nov 14, 2011 | 08:47 PM
  #45
808nickh's Avatar
what size hoses did you guys use in the swap and were did you get them. I was looking at some silicon hoses over at polyperformance, little pricy though.
Old Nov 14, 2011 | 08:54 PM
  #46
4Crawler's Avatar
I used 2.75" ID (rubber) hose to fit over the 2.75" OD AFM and throttle body ends:
- http://www.4crawler.com/4x4/CheapTri...shtml#Phase-II
Old Nov 14, 2011 | 08:57 PM
  #47
aviator's Avatar
FWIW you could have used the stock batt. tray/hold down if you had to... on toyotas up to 95.5 the left side of the engine bay is fitted with the body nuts and holes to use the tiedown since the 2L-TE diesels we did'nt commonly get here used a dual batt. set up.
It looks like on yours all you'd have had to do is drill a small hole in the flat spot on the front of the wheel well.
That is one beefy batt tray you made however...
Old Nov 14, 2011 | 08:59 PM
  #48
toyospearo's Avatar
nice work!
Old Nov 20, 2011 | 05:50 PM
  #49
What year supra afm? Does the plug match up with a second gen Toyota?
mskalmus
May 28, 2017 07:51 AM
93toyoguy
Aug 2, 2015 07:41 PM
Logz808
Jul 26, 2015 07:09 AM
GeoRoss
Jul 24, 2015 03:03 PM
94whiterunner
Jul 12, 2015 07:15 PM
