PICS- Swapping battery and airbox.
Old Jun 25, 2008 | 06:52 PM
AJsArmor's Avatar
Seen this mod on here and since I didn't like the stock locations and setup anyways, SWAP IT. Had a brand new battery to use, of course it was bigger so I had to do a little more modification. Hard to see in the pic but I notched out a small section and made a corner for the tray to fit in.
Then of course built the tray. Since it does take up a bit more room decided to make it removable in case it was in the way of anything. Uses the old mounting points of the airbox.
Here's a couple pics of it in place.
Made up some new cables and the intake pieces are on the way. I'll take pics and post them up as I go.
Old Jun 25, 2008 | 09:31 PM
norcalsvx's Avatar
nice looks good.
Old Jun 25, 2008 | 10:16 PM
89silverpu's Avatar
Sweet!
Old Jun 26, 2008 | 06:28 PM
20twinz's Avatar
Ill be doing this mod as well after I swap cabs.
LOOKS GOOD! nice work.
Old Jun 26, 2008 | 06:37 PM
nix4x4's Avatar
Nice fab work.. but may I ask why you don't like the stock setup?
Old Jun 26, 2008 | 07:56 PM
20twinz's Avatar
I want to do it because the air has to travel sooo far stock and heats up so much more going over the radiator. It may not be a HUGE diff. in temp but any little bit will help with these 22RE motors.
That and its always fun to mod stuff.
Old Jun 26, 2008 | 08:03 PM
nix4x4's Avatar
Oh gotcha... you dont need an excuse to mod things here on yt
Old Jun 26, 2008 | 08:25 PM
AJsArmor's Avatar
Exactly, it was the whole air route thing but also the electrical. Putting in a 130 amp alternator so wanted the shortest path possible, wasn't hard to make up new cables for everything. HUGE improvement over the stock stuff. That and I had a "know it all" type stop by the shop who said it wouldn't work- that usually does it for me.
Old Jul 1, 2008 | 05:56 PM
20twinz's Avatar
Haha! Me too. Thats all the motivation I need.
Old Jul 5, 2008 | 07:14 PM
AJsArmor's Avatar
Some more progress. Gotta pickup a piece of tube, pretty short one at that.
But I made a bracket to hold the AFM, cut a hole in the fender to get the filter sucking more cooler air.
Can't really see it in the pic but there's a stainless steel splash shiled in the inner fender to prevent water from hitting the air filter, eventhough the fender liner is still intact.
Post up some pics of the wiring soon.
Old Jul 6, 2008 | 04:49 PM
slacker's Avatar
nice work .. love the new battery tray , and detail ..
but ..
why wouldnt you remove the OLD battery tray ? .. seems a little less to me ... just my opinion .
Old Jul 6, 2008 | 05:03 PM
AJsArmor's Avatar
Well it's welded in, which meant cutting, grinding, painting.... But it was in good shape, no rust or anything plus it does add some structural rigidity to that area so figured I'd just leave it.
Old Jul 7, 2008 | 08:48 AM
cadman's Avatar
Best battery tray swap I've seen yet. I need to relocate the battery for my 3.4 swap and have been going back and forth on the best way to do it. I'm going to fab one up like yours. The removability factor is nice, along with utilizing the airbox mounts. Nice job.
Old Jul 7, 2008 | 08:53 AM
zlathim's Avatar
Nice looking mod. Good job making things look clean.
Old Jul 9, 2008 | 05:48 AM
20twinz's Avatar
I like how you polished everything up. Looks good. I may have to play copy-cat and do mine up like yours. looks good yet everything done is fuctional and improves somthing in one way or the other. I LIKE!
Old Jul 12, 2008 | 06:00 PM
AJsArmor's Avatar
Finally got the runner mobile last night. Still have to do some tuning/tweaking but very happy with the setup. With the Thorley header, Engnbldr 268 cam, b&b injectors, some porting... it runs a lot smoother and has noticeably more power.
Daughter happy I got it done finally!
Old Sep 5, 2008 | 07:34 PM
20twinz's Avatar
Just went back threw checking out your engin compartment and noticed in the last pic of your truck that your daughter has an IOWA shirt?......
Old Jan 6, 2009 | 08:42 AM
Windsor's Avatar
nice work!
Would there have been enough room to put the air cleaner back by the charcoal canister and u-bend between the AFM and TPS?
Old Jan 6, 2009 | 01:36 PM
DupermanDave's Avatar
What size of tubes are those connected to the vafm? (both the inner metal tube and the rubber tubes)
Also, what model of air filter is that?
Old Jul 30, 2009 | 04:20 PM
86_RunnerSR5's Avatar
I am interested in doing this batt relocation. But i waa wondering how did you get the AFM wires to reach the opposite side? Did you pull the wires off fromt he main wireharness and set it on the opposite side..
PS> SOrry for bringing this thread back from the dead. But i am interested in this MOD.
