My winter rebuild (7MGTE overhaul)
Old May 24, 2006 | 09:37 AM
  #161
NCSU-4runner's Avatar
About half way done cutting tubing for the intake. got my bling new sliders from Stubbs Welding in the mail and the best part. . . they were FREE thanks to the raffle at the SE4RJ
progress not going QUITE as fast as i wanted this past week but at least i have a good looking excuse. Date #2 with her is tonight and yes my 4runner is very jealous
Old May 24, 2006 | 10:21 AM
  #162
snap-on's Avatar
dude i dont know... you think you found a fuel cell that was BIG enough? i dont know....
looking good.
Old May 24, 2006 | 11:33 AM
  #163
sometimes i wish i'd gotten the smaller one, sometimes i dont. Yea its big but having a 32 gallon capacity has its perks for long trips. Especially for a monster that likely wont get jack for MPG.
Old May 25, 2006 | 03:01 PM
  #164
Finished cutting and fitting the air intake tubing. It's tack welded together and ready to go to my machine shop friend that REALLY knows how to weld. I'd try to do it myself but dont want to risk wasting the EXPENSIVE mandrel bends and having the possibility of leaks in the welds. I'll put up pictures when its ready for paint.
Old May 26, 2006 | 11:02 PM
  #165
fuel lines are now pressure tested. Gauge reads a steady 30 psi. It's getting closer. . . .
Old May 27, 2006 | 06:17 AM
  #166
brandontrek's Avatar
i want pics...i want pics....
glad to hear it is comming along....
Old May 31, 2006 | 05:56 AM
  #167
air conditioning died at the machine shop that is going to weld my air intake so everyone has been given vacation time till it gets fixed. Not many people too keen on welding indoors in 95+ degrees with high humidity and no air flow.
i did decide however that im gonna send the intake tubing and exhaust manifold off to get ceramic coated
Old May 31, 2006 | 01:39 PM
  #168
Stump1883's Avatar
Glad this is your project money bags, $$$$, and not mine
Old May 31, 2006 | 09:40 PM
  #169
just got back my federal and state income tax returns (they came to my parents house) so that puts quite a dent in my credit card bill. hooray for free'd up mod money
Old Jun 11, 2006 | 10:52 AM
  #170
updates?
Old Jun 11, 2006 | 04:32 PM
  #171
negatory. been busy with work and a new girlfriend, ill get back to work on it ASAP
Old Jun 12, 2006 | 11:28 AM
  #172
air intake came back from getting welded today. Test fitting before its sent off to be ceramic coated by jet-hot coatings.
Old Jun 12, 2006 | 11:31 AM
  #173
as you can see i'm not doing an intercooler at this time. It should be fine for <8-10 psi. If i want to turn the boost up eventually i have to re-do it but if i'm gonna go through that much trouble i'll get a front facing intake manifold made so the pressure side of the turbo doesnt have to cross the top of the engine.
While that tubing is off at the ceramic coaters i'm going to work on the rest of the electrical work i need to tie up.
Old Jun 12, 2006 | 03:52 PM
  #174
Stump1883's Avatar
Nice work dude, looking real sweet. Can't wait to finally hear it fire and spool up. Psssshhhh.
Old Jun 12, 2006 | 05:59 PM
  #175
thats why i got a nice aftermarket Blow-off valve (the HKS unit next to the fuse box for those not aware) that vents to atmosphere. Much louder than the stock one that recirculates back to the intake.
Old Jun 13, 2006 | 09:16 PM
  #176
Keggo's Avatar
good lord that is sweet... I'm saving up for the 7mgte...... MMMM.. I'm gonna overhaul it before I put it in the truck though.
Old Jun 16, 2006 | 05:50 AM
  #177
Bumpin' Yota's Avatar
Originally Posted by NCSU-4runner
Ok fuel lines are basically done. Somehow i managed to lose one of the compression nuts for the hardline-to-AN fittings so i can't pressure test it till i get a replacement, but everything appears to be fine. Pictures. . . .
I detect 1/0 and 4ga! (if im seeing the scale correctly otherwise 4ga and 8ga) So what are those wires dooooin? Why did I read this thread? Now I wanna 7mgte instead of rebuilding my 3vze's top end! BAD NCSU BAD! LOL So how goes it?
Old Jun 16, 2006 | 06:14 AM
  #178
The copper cable is going to the starter, the red cable is some leftovers from my old car stereo that i used to wire the main lead to the fuse box. Theres no stereo equipment in the truck for now (you can see the rats nest of wires where my amps used to sit behind the sub box which was about the size of the fuel cell now in the same position) but i plan to put a little something back in it eventually. I don't recall the gauges of wire off the top of my head. I mounted my battery in the rear of the truck so obviously i had to run all new leads for the powered components. The red wire is actually just running up the middle of the cab for now because i didnt have enough length to curve it around the edges to hide it. It will get cleaned up eventually.
It goes well. The intake piping is off the the cermaic coaters and I am going to try and knock out all the Autometer gauge, fuel controller, and wideband wiring this weekend so its ready to go when the intake comes back. Slap the radiator and ignition stuff on after that and it "SHOULD" fire up. . .
Old Jun 18, 2006 | 01:15 AM
  #179
Keggo's Avatar
In cali you have to use the original fuel tank, you can't use any sort of aftermarket fuel cell... sucks...
Old Jun 18, 2006 | 08:51 AM
  #180
I'm gonna register it in South Carolina (through my parents), they don't have ANY inspections there safety/emmissions/whatever. If it moves its legal.
