My FJ40 Buildup
Old Mar 14, 2006 | 01:35 PM
dragr1's Avatar
Subscribing on, nice work so far!
Old Mar 14, 2006 | 04:08 PM
Mad Chemist's Avatar
Thanks guys, you're good motivation to keep working on it!
Old Mar 16, 2006 | 08:20 AM
JBSTRD's Avatar
Awesome David, can't wait to see it out wheeling!
Jason
Old Mar 26, 2006 | 06:21 PM
UPDATE!
Okay, time for an status update on what I've been up to. First things first, installed new mechanical fuel pump for the 350 v8, uses a push rod from the cam to pump fuel. Its more reliable than the electric, though I'll keep the electric for a trail spare:
Old Mar 26, 2006 | 06:26 PM
  #25
Installed transmission support brace from Advance Adapters, had to modify the brackets a bit so that I'd be able to remove the brace without too much trouble:
Attached Thumbnails My FJ40 Buildup-fj40buildtranny1.jpg   My FJ40 Buildup-fj40buildtranny2.jpg
Old Mar 26, 2006 | 06:29 PM
  #26
Picked up new radiator from Cool Cruisers of Texas, 4-row, compared to the stock 3 row. I want to make sure I've got plenty of cooling power on the trail. Made a real fancy coolant reservoir, cost about a dollar:
Attached Thumbnails My FJ40 Buildup-fj40buildrad1.jpg   My FJ40 Buildup-fj40buildradhoses.jpg   My FJ40 Buildup-fj40buildradres.jpg
Old Mar 26, 2006 | 06:31 PM
  #27
Installed a "transfer case saver" which is a safety precaution with the older style Landcruiser transfer cases, which have a split case design. This bracke helps to hold the two halves together:
Old Mar 26, 2006 | 06:34 PM
  #28
Installed a Hayden tranny cooler, gotta keep that th350 nice and chilly:
Attached Thumbnails My FJ40 Buildup-fj40buildtrannycooler.jpg   My FJ40 Buildup-fj40buildtrannycooler2.jpg
Old Mar 26, 2006 | 06:42 PM
  #29
Common problem with the cruisers is the output shaft for the transfer case, that goes into the emergency brake drum has a seal that goes bad and leaks gear oil into the brake drum. Picked up a speedi sleeve that taps onto the shaft, increasing the diameter just a tinge to give a better fit with the TC seal. The seals on the front and rear TC output and the front and rear pinion were also changed while I was at it.
Attached Thumbnails My FJ40 Buildup-fj40buildtcseal.jpg   My FJ40 Buildup-fj40buildtcseal1.jpg   My FJ40 Buildup-fj40buildtcseal2.jpg
Old Mar 26, 2006 | 06:45 PM
  #30
waskillywabbit's Avatar
Dang David...you been busy!
Looking good!
Old Mar 26, 2006 | 06:46 PM
  #31
So...went to reassemble the tc brake onto the tc, and realized that I wasn't going to have enough clearance between the drum and the crossmember that runs between the two frame rails. I had to spend some time with a cutting disk and an angle grinder to cut it off. Had a bit of steel lying around, was actually the old front bumper that I've been hacking pieces off as I need them. Got everything welded back into place, and the braces will serve as a mounting point for a skid plate, eventually...
Attached Thumbnails My FJ40 Buildup-fj40buildcross1.jpg   My FJ40 Buildup-fj40buildcross2.jpg   My FJ40 Buildup-fj40buildcross3.jpg
Old Mar 26, 2006 | 06:49 PM
  #32
The finished product, plus a to-do list that is getting progressively smaller. Stay tuned for more next week.
Attached Thumbnails My FJ40 Buildup-fj40buildlist.jpg   My FJ40 Buildup-fj40build-pictures1-036.jpg
  #33
SnoViking's Avatar
what has your budget been so far for this deal? it should come out to be a great truck... im continplating picking up a fj40, but the wifeasaurus would kill me
  #34
Thanks Brian!
Hi Pat- bottom line, its an expensive endeavor to do right. Its all the little stuff that adds up, seals, fittings, etc. I bought the vehicle for ~3,000. I'm probably ~2,000 in parts, paint, etc, and still have a ways to go. They're old vehicles and require alot of TLC. However, they're relatively easy to work on, especially for a novice like myself. The body is pretty junky, so I don't even pretend that this is a restoration. My goal is make it look relatively good on the street, make it reliable both on and off road.
Old Mar 26, 2006 | 06:58 PM
  #35
1985 4Runner's Avatar
Great buildup! I need one of those tranny coolers for my th350.
Keep up the great work!
Old Mar 26, 2006 | 07:21 PM
  #36
midiwall's Avatar
WOW David! I didn't know you were back working on her!
WELL DONE!
YAY!
Old Apr 3, 2006 | 04:13 PM
  #37
yotarunner96's Avatar
this is just what i want to do this summer. your fj looks great!! the only thing holding me back is the fact that i am a collge kid and "another" vehicle is not needed, even though it is very very much wanted. keep up the good work!
Old Apr 3, 2006 | 05:09 PM
  #38
Thanks!
Sleaker
Aug 26, 2020 06:03 AM
ToyotaMD
Aug 17, 2018 10:16 PM
cruisin69
Early Land Cruisers (Build-Up Section)
34
May 22, 2018 12:25 PM
bhaithc
Sep 17, 2015 07:53 PM
idadan208
Sep 7, 2015 09:06 AM
