leveling shim....need help
Old Jun 10, 2011 | 06:45 PM
yotadoug's Avatar
is 3/8's always the thicknees for spring perch shim? how can i tell without installing lift springs first? as of now axle striiped and ground, im ready to install new perch's with corrected driveline angle.....help......
Old Jun 11, 2011 | 01:48 PM
4rnnr33's Avatar
Yes because the passenger side sits up on the diff making it 3/8 higher than the drivers side. Did you cut and turn your knuckle balls or something?
Big Little Bear
230
Nov 13, 2023 11:42 AM
beebeeri000
Oct 2, 2015 10:42 PM
charlie_fong
Sep 27, 2015 10:06 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
Dparr2ndgen
Sep 8, 2015 01:06 PM
