high steer probs
Old Dec 18, 2004 | 05:11 PM
bigamigo's Avatar
high steer probs
i am havung a issue with my high steer i just built it has got some bump steer and i thoght that this was the fix or that prob
Old Dec 18, 2004 | 06:20 PM
waskillywabbit's Avatar
stop drinking beer and post again...
Old Dec 19, 2004 | 09:01 AM
Is it bumpsteer of death wobble? If woble try playing with the shackle lengths. I run unbalanced 38's with no steering stabilizer and have no bumprsteer and a very very light trace of death wobble
Old Dec 21, 2004 | 10:21 AM
4x4guy74's Avatar
Death wobble is some bad stuff. I solved a case of death wobble by correcting the toe. As for bump steer you should be getting very little of that. Unless your drag link is at a severe angle. Try to get the drag link as level as you can. You might need a drop pitman arm. Whatever you do don't run a Z link. It won't solve the bumpsteer because the angle from TRE to TRE will be the same. And Z links are just weak and unsafe.
Old Dec 22, 2004 | 05:58 AM
bigamigo's Avatar
check out the amigo site to see the steering the drag link cant get more level but i think that i found out my issue i have a bad heim joint so i am thinking that could be the prob
Old Dec 22, 2004 | 03:11 PM
bigamigo's Avatar
Talking
i was wrong i had a bolt come loose had one that was not a poly lock fixed it seems to do a lot better now also lots of new pics at my amigo site what do you think :xmas3:
delmert
Sep 30, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
Up&Down
Aug 5, 2015 06:20 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
bobpat
Aug 1, 2015 09:25 PM
