GM 15" wheels
Old Aug 5, 2008 | 06:57 AM
plumo57's Avatar
GM 15" wheels
Okay, just spent 50 bucks on a set of 5 steel GM wheels. I know i need to open up the center hole (from 3.5 to 4 inches as i understand it) Someone posted that a holesaw would work, but it seems like i'd need to fab up a really good jig to ensure it was centered right. otherwise, i could use a die grinder although it wouldnt be as nice and round. Any suggestions or opinions (i know, you all have opinions) on this?
I have pictures, but am not smart enough to figure out how to put em on here... if its important enough to anyone, feel free to explain in to me.
Thanks all.
Old Aug 5, 2008 | 08:11 AM
kampgnar's Avatar
Recently picked up some GM rally wheels on a whim. Haven't got around to enlarging the hole yet, but I was planning on outlining the diameter of the hole that would be enlarged and just grinding it out to the line.
I've heard of people torching the material out. Was thinking of possibly finding someone with a plasma cutter to make it super easy.
Not too worried about the roundness of the hole as long as it is structurally sound. The centercaps would cover it up...unless you don't have the centercaps.
Old Aug 5, 2008 | 10:59 AM
RobD's Avatar
A coarse cylinder hone and a big drill!
Or find someone with a lathe.
Old Aug 5, 2008 | 07:00 PM
jeremyfx4's Avatar
If you were closer I could hook you up with some nice 4" holes. It just so happens that i did the same thing with some alum. chevy wheels. But I program and run cnc mills so all i did was take em to work clamp them down on the table of the mill, indicate the center hole and write me a little program to come down with an end mill and bam the holes were enlarged.
Old Aug 5, 2008 | 07:09 PM
Jay351's Avatar
It doesnt have to be absolutly perfect. The wheels on toyotas are lug centric, not hub centric.
Old Aug 6, 2008 | 05:35 AM
plumo57's Avatar
Looks like i'll be using the grinder. i appreciate the advice. i got center caps with the wheels but wasn't sure if theyd fit. guess i'll find out.
Old Aug 6, 2008 | 04:56 PM
SKULLYOTA's Avatar
you can use a hole saw the same size as the original hole as a pilot to help you drill it out. just put both hole saws on one chuck if you can. thats what my dad did a few years ago.
oh yeah and hold on tight!
Old Aug 7, 2008 | 05:09 AM
plumo57's Avatar
that actually sounds like a damn good plan....
Old Aug 7, 2008 | 05:27 AM
massyota's Avatar
put a backing plate behind rim and bolt it up thru the lug holes the you can use that to get a center for the hole saw with a piolt hoe for the hole saw that way it wont walk
Old Aug 7, 2008 | 02:53 PM
SKULLYOTA's Avatar
that oughta work too, using a holesaw that big can give you a ride if you're a lightwieght guy (like me) and i think after the 4th rim the drill blew when we did it.
those GM wheels are goodlooking rims, and 50 bucks sounds like a great deal
Old Aug 8, 2008 | 04:56 AM
plumo57's Avatar
yeah, God Bless Craigslist. for five of em too... and it turns out the guy worked at teh desk next to my little brother, so i didnt even have to drive to go pick em up. They need a little TLC and a repaint, but they're straight n true. I'm gonna give the holesaw idea a shot.
Old Aug 8, 2008 | 07:19 PM
SKULLYOTA's Avatar
good luck, the trim rings and caps for those rims are readily available through jcwhitney, if you are into that look and don't have them...
Old Aug 9, 2008 | 04:56 AM
plumo57's Avatar
I'm into the fewer parts you have, the less stuff you have to break. Reliability is king.
Old Aug 10, 2008 | 07:13 PM
SKULLYOTA's Avatar
how'd it turn out? i used to run the trim rings back when my truck was clean and nice, but now i also have no use for them.
i just (today) bought the front 4.88 carrier out of a 4runna' and i'm getting a matching rear soon.. ... i'm stoked!
Old Aug 12, 2008 | 03:57 PM
plumo57's Avatar
Congrats on the 4.88s. I haven't had time or money to buy holesaws of that size yet, so the project is on hold for now. biggest i got is a 2 inch.
Old Aug 14, 2008 | 06:56 PM
SKULLYOTA's Avatar
well i got a complete front off of a automatic 4runner, 150 bucks.
i don't own the rear yet, hopefully i won't have to spend the time to do my own gears. there aren't that many toyota gurus in west montana, so good parts like that are hard to find.
hope your wheels turn out,
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
