Frame ideas?
Old Feb 1, 2013 | 01:38 PM
bsmith's Avatar
Frame ideas?
Hey folks I'm looking for some help I'm turning a 75 toyota chinook into a 4x4, I'm wondering if its possible to weld the Back half of the frame from the chinook
to my1989 toyota pickup, anything would help. Thanks
Old Feb 1, 2013 | 01:51 PM
wyoming9's Avatar
Red face
I don`t know if you could weld it!!
But I know I could so that means yes it could be done.
it would just be like any other frame splice .
lots and lots of prep work the welding is the easy part. getting it all lined up square can be interesting
The real work comes in installing the brake lines , E-brake cable and fuel lines things like that.
Sizing the drive shaft
something like this I would charge time and materials off the top of my head at least $ 2000 to 3000 maybe more.
Old Feb 2, 2013 | 04:15 AM
wyoming9's Avatar
Red face
Some more things that you might need to think about.
i take it the whole project is to have a 4x4 camper.
In this case I think your doing things back wards
It would be much easier to install a front section of A 4X4 frame to the chinnok .
Only because to do this correct it would need to be stripped down to the bare frame pretty much .
This is one of those things that really needs lots of pre planing .
It could be that the frame widths are different just making things more interesting and time consuming .
Didn`t someone do these conversions if I recall I remember seeing or reading something at one time
Old Feb 2, 2013 | 04:23 AM
motocrossaddict223's Avatar
Wouldn't it be easier to just put the driveline and front axle from a 4x4 truck?
Old Feb 2, 2013 | 07:26 AM
wyoming9's Avatar
Red face
Hard call to make on this without looking up close and personal.
No matter how you go about it there will be lots of fab work .
If the frames are different width .
You get into moving spring pads while no big deal if not done correct can cause major alignment issues.
we all should know with enough money and time all things can be done till it is all said and done it will end up to be cheaper and go buy a full size truck of your choice and a slide in camper.
Even being used to the small engine add even more weight then your gonna want more power .
Old Feb 2, 2013 | 03:00 PM
bsmith's Avatar
Thanks for the input, I found a 86 long bed 22r on Craig's list today for1100 I think I'm gonna jump on it , put the chinook on and save a bit of money and be on the road by summer ( hopefully) I appreciate the ideas
young buck
18
Aug 27, 2018 02:40 PM
gieselman
Mar 20, 2016 04:34 PM
DrZero
18
Jul 24, 2015 11:31 PM
yourrealdad
Jul 21, 2015 11:13 AM
