fabing a frame drop
fabing a frame drop
so i saw that my buddy had a frame drop system on the front end of his truck and realized how much easier it is on the cv axles. do you think i can custom fabricate a frame drop system out of 3/8 to a 1/4 inch sheet of metal? my truck is a 86 with a 5spd. it doesnt seem to complicated but im asking before i do it. thanks for the help
Do you mean a bracket lift? Rough Country Bracket Lift
If you're a really good fabricator I'd say you can do it if you really want to, but by the time you're done fabricating all of that the cost of steel and the time you spent will most likely end up costing you more than that. Not to mention it already comes with four shocks and longer coils for the back.
even if you made the brackets for yourself, you'll still need new shocks, probably $160 there. Extended brake lines another $20. Mounting hardware's probably another $40 if you get Grade 8. Sway bar drop brackets are around $80 last I checked. Add-A-Leafs for the back are over $100.
So that comes out to $400 for everything other than the brackets before shipping and tax.
I'm not trying to dissuade you, I just want to put it into perspective. If you are or know a professional fabricator that's willing to do the work for free, then go for it. Otherwise, I'd just save your money and get the bracket lift with all the parts included.
I'd personally never put a bracket lift on my truck because it doesn't raise ground clearance, but if you're just doing it for looks then go at it.
There's a reason why lift companies spend millions in R&D on DB lifts, Because it takes alot of stuff to get it right..
If your gonna do it, buy one!! Buy a used one off of craigslist.
OR, Do it right and SAS the damn thing.
sure you could make one, but are you confident that you could get the geometry correct, stable etc so the caster etc is right? Not saying you could not do it, but seems like it would be opening a bad case of death wobble...
lowest cost: cut your fenders...
JustMike
Apr 21, 2016 07:08 PM
FS[PacSouthWest]: FS: 1988 4RUNNER FRAME 4X4 IFS Located in Lancaster Ca
4x4-runner
Aug 30, 2015 08:55 AM
Tacoma1313
Aug 17, 2015 05:44 PM
