Double Cab Coilover SAS
Old Feb 19, 2006 | 06:17 PM
ROCK TOY's Avatar
This is one of the boards I quietly observe to learn so I thought I would share some... I've started my sas of my 04 Double cab based on Dean's (Tacodab) & Tacominaor (Jake) over on TTORA. Mine is also similar to SteveO's. Any way here are the technical details: 14"Fox coilovers, wide track d44, fr/rr arbs, 4.88 gears, marlin dbl cases with stock gears (auto trans) parts mike high steer knuckles, sky high steer arms, front range transfer case x-member, trd s/c with urds upgrade kit, going to build my own bumper with warn 9.5ti, rock sliders and rear bumper, rear suspension will be chevy 1/2 ton, bed is going to be bobbed, front is 3 link with a panhard bar and antirock sway bar.
Here are some pics.
Don't hesitate to as any questions I'll do the best I can to help anyone that wants to try this.
Presto, a clean slate!
A new front crossmember
extraction gear
putting together the marlin puzzle
the kind of joints that don't get you in trouble...
the best way to shop at your local salvage yard!!!!
Front Range holding double cases
Old Feb 19, 2006 | 06:29 PM
ROCK TOY's Avatar
some more pictures....
making the crossmember mounts
welded up
nicely welded up jj ends
tabs fabbed and welded onto crossmember
tabs fabbed and welded to axle, little test fitting
Upper link done, perfect so far
oops, sway bar wont work, gotta move it in front of the axle, oh well, live and learn
"jacke flex"
how I did my brackets in relation to everything else
why the sway bar had to be moved....
more jack flex, steering and knuckles are temp pieces for mock up purposes
Much more to come
Steve
Old Feb 19, 2006 | 08:57 PM
4rnr's Avatar
Ummm..... Damn nice....yup
I need coil overs Im sick of my leafs, ive had them long enough!
Old Feb 20, 2006 | 07:17 AM
SteveO's Avatar
Steve, nice job on the cross member. Looks familiar..
How did you get the bolts welded to the inside of the box tubing? Very trick job there.
BTW, I finally got more info up on my site about my SAS, nearly a full write up..
http://www.hunt4steve.com/99RunSas.html
Old Feb 20, 2006 | 07:43 AM
Cebby's Avatar
Nice work! ...and thanks for sharing it with us here!!!
Old Feb 20, 2006 | 11:24 AM
bruzer1123's Avatar
Wow that is super sweet! Can't wait for more pics!
Old Feb 20, 2006 | 11:51 AM
garrett1478's Avatar
i was wondering the same thing...
Old Feb 20, 2006 | 12:27 PM
snap-on's Avatar
you can always weld the nuts to a small piece of sheet, then slide that into the tube and weld the sheet at the edges. accomplishes the same thing with out fighting the mig gun in the hole
Old Feb 20, 2006 | 03:31 PM
Robinhood150's Avatar
Total guess here, but I'm thinking he stick welded it.
Old Feb 20, 2006 | 05:44 PM
ROCK TOY's Avatar
Thanks Steve, you, Jake and Dean are my constant references.... hence the similarities. The nuts welded in the box are realatively easy, started on the inner two and worked out, box is bigger than you think and fairly easy to fit the mig gun in. Only took a few minutes per side. Worked on coilover hoops today as well as tabs. Drivers side is going to be fun fitting steering shaft, hoop, sway bar and panhard bar mount. Should have a few pictures up tomorrow. Sway bar is not in its exact location yet. Oh yeah, Steve your web site is awsome, great info and best looking 3rd gen runner IMHOP! Thanks for the compliments guys. One more note, this truck is going to be relatively low, frame at the front is going to measure about 27-29" at finished ride height and will be adjustable because of the coilovers.
Steve
Old Feb 20, 2006 | 06:18 PM
4RocRunner92's Avatar
you steves
Old Feb 21, 2006 | 07:19 AM
SteveO's Avatar
Thanks man, much appreciated. If you have any questions, drop me a line.
I know you have been grillin Dean on TTORA, and and I'm glad to see another Coil-over sas coming up. The ride is sooooo much better than springs, and worlds better than springs that have shackles in the front, like jeeps.
Old Feb 21, 2006 | 11:06 AM
dragr1's Avatar
Nice!
Old Feb 21, 2006 | 11:13 AM
WATRD's Avatar
VERY nice work
Old Feb 21, 2006 | 01:15 PM
ROCK TOY's Avatar
Thanks guys, here is what we worked on today. Drivers side hoop and coilover mount. Repositioned the sway bar, going to have to recess it into the frame to make it clear pitman arm tre bolt.
[IMG]http://i46.photobucket.com/albums/f147/goinmxn/100_0166.jpg[/IMG]
Old Feb 21, 2006 | 01:38 PM
shazaam's Avatar
dag, looks awesome!!
Old Feb 21, 2006 | 01:42 PM
nice
Old Feb 22, 2006 | 11:26 AM
ROCK TOY's Avatar
Thanks for the compliments,
back to work: steering shaft done, now working on the firewall plate
Old Feb 22, 2006 | 11:53 AM
Tacoclimber's Avatar
Man, just when I started to get content with my DC the way it is, I gotta go an see this thread! Seriously, great job - amazing build. I can't wait to see it done!
Old Feb 22, 2006 | 01:59 PM
ROCK TOY's Avatar
Firewall steering plate done!
