Dana 60's for SAS
Old Mar 16, 2004 | 10:07 AM
  #41
upndair's Avatar
No, those shock mounts are well secured. They needed to be that low to keep the shock from bottoming out. I may however move them once I weld the blocks on the perches. The butt's a little saggy...
I don't drive it daily as I work from home. I did drive it to the trail last weekend. No vibration issues at all! The only problem is that the splines on the front driveline are worn and make a little noise. To save unnecessary wear and tear, I pulled the driveline off at the diff and hung it up for the trip.
My truck was gutless with 29s! I should just sell 4th and 5th gear. They'll never get used! A new motor is in the works as I have a bad rod knock as it is. I'll be going either with the 3.4L Toy motor or the 4.3 Chevy.
You're better off with your pickup. Less body to damage...
Old Mar 20, 2004 | 08:15 PM
  #42
upndair's Avatar
Thought you might want to see some finished pics.
I'm still having a few problems with the steering up front - mostly the infamous death wobble. I don't have the alignment completely tweaked yet and the RAM assist is not installed yet. I changed the ARB blue lines to the yellow coiled standard air lines.
I have to block up the rear a couple inches to get the truck level. Right now it still sags a bit in the butt.
Despite significant trimming of the rear wheel wells, I still rub, but after I get the rear up a little and bump stop it, I'll this everything will fit OK.
Direct from the rear. http://209.20.253.189/ramp1.jpg
Left side view. http://209.20.253.189/ramp2.jpg
Front view. http://209.20.253.189/ramp3.jpg
Left front bump stop. http://209.20.253.189/ramp4.jpg
Left corner view. http://209.20.253.189/ramp5.jpg
Left rear All Pro Johnny joint. http://209.20.253.189/ramp6.jpg
Right rear compressed spring. http://209.20.253.189/ramp7.jpg
Right front close up. http://209.20.253.189/ramp8.jpg
Right rear close up. http://209.20.253.189/ramp9.jpg
Right side view. http://209.20.253.189/ramp10.jpg
Old Mar 21, 2004 | 03:43 PM
  #43
upndair's Avatar
A few pics on the ramp today.
JookUpVandetti
Sep 30, 2015 08:58 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
Flying91
Sep 10, 2015 03:41 PM
