cv replacement HELP!!!
Old Oct 24, 2007 | 12:23 PM
4Runner202020's Avatar
i cant seem to get the axle shaft outta the spindle i took the four bolts out and all.... what can i do. its just sittin there now!!! lol
thanks
bobby
Old Oct 24, 2007 | 12:37 PM
bump i need help!!! lol
Old Oct 24, 2007 | 12:39 PM
Bighead's Avatar
Did you take off the dust cap and pull off the 35mm nut under that?
Old Oct 24, 2007 | 12:43 PM
yes i did get all that dont. the forum i'm using it says it just slides out and it sure isn't lol
Old Oct 24, 2007 | 12:53 PM
bump...
Old Oct 24, 2007 | 12:55 PM
Bighead's Avatar
Have you separated the spindle from the lower control arm? You also might need to give the end of the axle a couple of whacks with a hammer to loosen up the splines.
What online write-up are you using?
Old Oct 24, 2007 | 12:57 PM
i cant get i loose from the botom spindle.... its killing me!!!! awwww lol
I'm usin this one though
http://www.4x4wire.com/toyota/maintenance/cv_axle/
Old Oct 24, 2007 | 12:59 PM
Bighead's Avatar
Look at the pic labeled Step 17 in the write-up you are using...if all 4 bolts are out, get a long prybar and separate the spindle from the LCA. There might be some rust keeping everything together.
Old Oct 24, 2007 | 01:04 PM
what is the lac...
Old Oct 24, 2007 | 01:10 PM
Bighead's Avatar
Lower control arm.
Old Oct 24, 2007 | 01:21 PM
ya the spindle is seperated from the lac... its just the cv alxe is stuck in the spindle and i hit it a lot lol its not comin loose!!! any other tips would be great. thanks
Old Oct 24, 2007 | 01:27 PM
bump.
Old Oct 26, 2007 | 07:30 AM
weakyota91's Avatar
if the lower control arm is loose from the spindel and that 35 mm nut is off. just give it a good few tugs and it should pop out. there a little clip that hold the ends of the cv shaft in he diff
Old Nov 1, 2007 | 07:48 AM
89PICKUP/TACOMA's Avatar
Did you get over your bump???
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
