cv replacement HELP!!!
Have you separated the spindle from the lower control arm? You also might need to give the end of the axle a couple of whacks with a hammer to loosen up the splines.
What online write-up are you using?
i cant get i loose from the botom spindle.... its killing me!!!! awwww lol
I'm usin this one though
http://www.4x4wire.com/toyota/maintenance/cv_axle/
Look at the pic labeled Step 17 in the write-up you are using...if all 4 bolts are out, get a long prybar and separate the spindle from the LCA. There might be some rust keeping everything together.
if the lower control arm is loose from the spindel and that 35 mm nut is off. just give it a good few tugs and it should pop out. there a little clip that hold the ends of the cv shaft in he diff
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
