custom sway bar ...
custom sway bar ...
I need to build a "custom" sway bar for my Trekker build .. as it's mostly going to be a tow rig . with about ~280HP (3.4L supercharged) .
I know it's gotta be "spring steel" so ya just cant bend one up ...
I'm going to try a local spring shop , and hopefully they can help .. any Ideas ?
Why custom built? You can get bolt-on front and rear bars for the solid axle trucks, stock or from Addco.
Or get something like the Currie anti-rock sway bars:
http://www.currieenterprises.com/ces...s.aspx?id=1234
I need custom because of the engine swap .. I have the 3.4L and havnt swapped the oil pan .. I'm using the stock steering
I was considering swapping the pan , but it brings it to close to the diff for my comfort ..
Easy enougn to just lower the bar down off he frame enough to clear the pan. Since it appears you have lift springs on there, lowering the bar will help you run the stock length end links if you want:
OK, didn't know what height you needed.
Try something like this with an IFS or Tacoma sway bar behind the axle:
- http://home.4x4wire.com/erik/4runner/sas/#swaybar
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
sonorn67
Sep 19, 2015 05:39 PM
potatopants
Sep 15, 2015 06:26 AM
