custom sway bar ...
Old Sep 12, 2008 | 05:11 PM
slacker's Avatar
custom sway bar ...
I need to build a "custom" sway bar for my Trekker build .. as it's mostly going to be a tow rig . with about ~280HP (3.4L supercharged) .
I know it's gotta be "spring steel" so ya just cant bend one up ...
I'm going to try a local spring shop , and hopefully they can help .. any Ideas ?
Old Sep 12, 2008 | 06:51 PM
4Crawler's Avatar
Why custom built? You can get bolt-on front and rear bars for the solid axle trucks, stock or from Addco.
Or get something like the Currie anti-rock sway bars:
http://www.currieenterprises.com/ces...s.aspx?id=1234
Old Sep 13, 2008 | 07:13 AM
slacker's Avatar
I need custom because of the engine swap .. I have the 3.4L and havnt swapped the oil pan .. I'm using the stock steering
I was considering swapping the pan , but it brings it to close to the diff for my comfort ..
Old Sep 13, 2008 | 07:26 AM
4Crawler's Avatar
Easy enougn to just lower the bar down off he frame enough to clear the pan. Since it appears you have lift springs on there, lowering the bar will help you run the stock length end links if you want:
Old Sep 13, 2008 | 04:08 PM
slacker's Avatar
excellent thought .. but there is no way those would work for my application ...
I would need at least 6" blocks to clear the pan .. not good !! ..
Old Sep 13, 2008 | 04:11 PM
4Crawler's Avatar
OK, didn't know what height you needed.
Try something like this with an IFS or Tacoma sway bar behind the axle:
- http://home.4x4wire.com/erik/4runner/sas/#swaybar
Old Sep 14, 2008 | 03:43 PM
slacker's Avatar
gives me an Idea !!! .. thanks Roger .
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
toyotasaurus
Sep 24, 2015 03:30 PM
sonorn67
Sep 19, 2015 05:39 PM
potatopants
Sep 15, 2015 06:26 AM
mdh
Sep 15, 2015 12:12 AM
