Custom blocks, Any thoughts?
Old Nov 21, 2008 | 02:01 AM
CrazyEye's Avatar
Lightbulb Custom blocks, Any thoughts?
I have been thinking of putting 2 inch blocks under my truck. I have read gobbs of material that say not to block your front. But what if I were to machine these blocks big enough so that the U-bolts would go through them and leave plenty of meat that goes around the bolt. Any thoughts?
Old Nov 21, 2008 | 03:45 AM
Erik Hinch's Avatar
Don't do it! for the trouble you'd go to, it would would be cheaper and much wiser to put some springs under the front, beside some states don't permit the installation of lift blocks in the front.
Old Nov 21, 2008 | 06:15 AM
ozziesironmanoffroad's Avatar
also blocks are dumb period. all they do is make you look like a poser. spend the xtra money and do it right with springs
Old Nov 21, 2008 | 07:33 AM
4banginRunner's Avatar
to much time and effort for blocks
do it right the 1st time
Old Nov 21, 2008 | 07:34 AM
scuba's Avatar
check this...
https://www.yotatech.com/forums/f116...blocks-145125/
Old Nov 21, 2008 | 11:23 AM
CrazyEye's Avatar
Ok, enough said, Thanks guys for the input. I will do my lift the right way.
Old Nov 21, 2008 | 11:27 AM
4Crawler's Avatar
Another consideration up front with stock steering is that the steering J-am and drag link on the driver's side will hit the u-bolts (and bind up the steering) if you even try to add another leaf to the spring pack.
Sep 4, 2015 09:27 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
Dakotaneu
Jul 27, 2015 12:03 AM
toofly1999
Jul 25, 2015 07:09 PM
Edionne13
Jul 9, 2015 01:59 PM
