Control Arm Ideas...
Old Apr 17, 2005 | 08:23 AM
  #61
ravencr's Avatar
Hey guys, for those that think a gas tank relocation isn't worth it, check out these pics:
https://www.yotatech.com/forums/show...t=54684&page=4
Chris
Old Apr 17, 2005 | 08:26 AM
  #62
ravencr's Avatar
I fixed the upper link yesterday, and wheeled it on some hard trails to see if it was good. I didn't sleeve it or put any gussets on it, because after seeing how little metal was holding it together from the factory, it's way stronger than it was now just with some good solid beads of weld on it.
Chris
Old Apr 17, 2005 | 02:32 PM
  #63
Albuquerque Jim's Avatar
Chris
How did you weld it w/o melting the bushing out?
Old Apr 17, 2005 | 02:33 PM
  #64
ravencr's Avatar
Very carefully!
Chris
Old Apr 30, 2005 | 08:04 PM
  #65
customcruiser's Avatar
i have a question on axle placement......
i am running 38x15.50's, OME 860's, 2.5" panhard drop, and stock upper and lower links on a 94 4runner
when the truck is sitting level the tires look way too close to the front side of the wheelwells and look like they will rub like crazy, but when i drive or flex they rub on the rear bumper. i removed the bumper and the tires fit perfectly in the wheelwells with alittle rubbing at full flex.
if i extend the lower links and center the tires like i want to, it seems that the tires will rub and it will not be able to flex at all. or will extending both links fit this. i do have new heim upper links waiting install
Old May 15, 2005 | 07:10 AM
  #66
ravencr's Avatar
I've decided what I'm going to to for my rear lower links after wheeling this weekend at the SE4RJ. I saw a jeep that used 2" 7/16" thick tubing bent at roughly a 60-70 degree angle, welded together that created a downward L towards the axle. Talk about clearance. It was amazing! I haven't looked yet, but I'm going to try to mount them to the outside of the frame instead of the inside for more stability, but if not, they'll be just inside of the frame, longer than stock, and there won't be any snag spots on the frame this way.
Chris
Old May 16, 2005 | 09:55 AM
  #67
99_Runner's Avatar
Where's the pics. I would like to do the same to the rear of my runner, so post some pics durring the process.
Old May 16, 2005 | 10:17 AM
  #68
ravencr's Avatar
One of the guys on the trip took the pictures of the jeep that had them, so as soon as he posts the pics on the SE4RJ pics thread, I'll post them over here to show what I'm talking about!
Chris
Old May 16, 2005 | 11:31 AM
  #69
MellamoPOUND's Avatar
This might be a dumb question but is it bad to have my rear lower control arms bent upwards? Is it messing with the alignment of my axle or anything?
Old May 16, 2005 | 11:42 AM
  #70
ravencr's Avatar
Not a dumb question, but join the club. If you've wheeled on any rocks, you've bent your lower control arms. I got hung up in a very bad place on Guardrail at Tellico this weekend, and I almost wasn't able to go forward, because I was resting on my frame directly in front of my lower control arm frame location. Without it, I would have walked right over the rock face, but instead I had to use my highlift jack to raise the frame and let the jack fall as I moved forward.
But, to answer your question, being bent is normal if you have wheeled it. Does it affect the angle of your drivetrain: yes ever so slightly, unless they are majorily bent. Being a 1/4" off isn't going to hurt anything. I have had 3/16" angle iron on mine, and they are still bent, so I'm going to be using .5" DOM when I make my lower control arms, plus I'm going to double them up, because the curve adds a lot of undue stress on the link when backing up.
Chris
Old May 16, 2005 | 11:48 AM
  #71
Thanks for clearing that up for me Chris.
I guess I should add some angle iron to mine also. Should I just hammer the arms back while still bolted on then add the reinforcement?
Old May 16, 2005 | 11:56 AM
  #72
ravencr's Avatar
I wouldn't hammer it, but I'd use a bender to bend it back, then I'd go with 1" 1/4" angle iron instead of 3/16" thick?
Chris
Old May 18, 2005 | 01:12 PM
  #73
This is really hard to see, but here's a pic of what I'm planning to do with my lower rear links:
Chris
is it behind the red X?
Old May 18, 2005 | 01:50 PM
  #74
ravencr's Avatar
Apparantly! Here's the link to it:
http://community.webshots.com/album/348169134aygtyU
And here's another example of one similar:
Chris
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
kcaudill
Oct 10, 2015 02:39 PM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
