bumper build-up
Old Jan 11, 2011 | 02:50 PM
85chevyota's Avatar
bumper build-up
First off, I have a winch bumper but it sits too low and is too short. I wanted something similar to what SigEp4Runner did. https://www.yotatech.com/forums/f88/...inally-219699/
My original bumper is the first pic and the next is what my plan is.
[IMG]file:///C:/Users/NEILAL%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG]
Old Jan 11, 2011 | 02:53 PM
MaK92-4RnR's Avatar
why not raise yours and add to it?
Old Jan 12, 2011 | 09:17 AM
85chevyota's Avatar
the old one has brackets set to the bottom of the frame and i added a 3'' body lift. plus the time to add to the old one to make it like the new one would actually be inconvenient. I like the idea, trust me i wish i could...that was my first option
Old Jan 19, 2011 | 04:06 PM
85chevyota's Avatar
if i use 1/8'' metal all around and gusset the bottom of the winch box(blue triangles) will this be enough to support the winch without bends?
Old Feb 2, 2011 | 06:19 AM
85chevyota's Avatar
finally got the mock up done and it is ready to be put on autocad to be drawn up and cut on a laser. ill have the pic of the mock up on later.
Old Feb 10, 2011 | 02:44 PM
bobbyhill's Avatar
are u goin two sell your old bumper?
Old Feb 11, 2011 | 02:07 PM
85chevyota's Avatar
yes but the winch and lights are not included. pm me and well talk about it if you want to buy it or no somebody who would like to.
Old Feb 11, 2011 | 02:21 PM
85chevyota's Avatar
Old Feb 11, 2011 | 02:47 PM
89silverpu's Avatar
I would use at least 1/4" plate for mounting the bumper on to and the gussets for it. 1/8" is not going to be strong enough for heavy awkward pulls.
Old Feb 12, 2011 | 11:35 AM
85chevyota's Avatar
my old bumper is 1/4'' and doesn't have any gussets at all plus it's only stitch welded not solid. i figured if i put (4) 1/8'' gussets under the bottom plate and ''skid plate'' it would hold but i may be wrong after all this is my first structural fabbing that i have done so any ideas would be good.
Old Feb 12, 2011 | 11:38 AM
camo31_10.50's Avatar
why not just go ahead and use 1/4?
or 3/8's
i'd rather have something and not need it, than need something and not have it.
Old Feb 12, 2011 | 12:23 PM
85chevyota's Avatar
i agree, i would hate to be winching and my winch goes flying
Old Feb 12, 2011 | 07:47 PM
chrishf12's Avatar
^^that could be a deadly mistake...go for the 3/8 or 1/4
Old Feb 13, 2011 | 12:06 AM
wyoming9's Avatar
Red face
Your bumper is only going to be as strong as what it is attached to.
Are you planning to bolt this or weld this to the truck??
Or are you making your own welded on brackets that the bumper will bolt too.
I also have a tendency to over build things as well.
That is a call only you can make.
Happy fabbing
Old Feb 15, 2011 | 04:29 PM
85chevyota's Avatar
ok so im in a slight situation. this is how the mock up cardboard sits to how i want it. it sits 3'' above the frame under the winch box and about 2'' from the gusset to the frame. does anybody know where to get a bracket or what i can do?
Old Feb 15, 2011 | 08:28 PM
4runazdiesel's Avatar
make a bracket that you bolt to the frame and weld it to bottom of the winch box and what ever else you can make it touch
Old Feb 15, 2011 | 08:48 PM
Birdbrain's Avatar
3/16's should be fine...
Old Feb 17, 2011 | 08:48 AM
85chevyota's Avatar
this is what i could come up with
Old Feb 17, 2011 | 09:23 PM
so that bracket would be bolted to the both the frame and the bumper?
that looks like it can be easily re fabed if you remove your body lift
Old Feb 18, 2011 | 06:34 AM
85chevyota's Avatar
ok so i have figured out what i'm going to do and please correct me if y'all think it can't handle it. i want to bolt my winch to a 1/4'' plate and have that plated welded or bolted on to the front cross member. doing this will eliminate the winch box and i can make my bumper out of 1/8'' and the bumper itself wont have any stress at all.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Scotttekoch
Sep 28, 2015 10:30 PM
83
Sep 27, 2015 04:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
