Bumper Build
Old Nov 29, 2009 | 03:16 PM
peow130's Avatar
Bumper Build
Welp, for my senior project i decided to make a winch bumper.
I kinda liked the way Ed H did his bumper, so props to him for the inspiration.
I started with about 5 feet of 4" C-channel, and 3 feet of 6" C-Channel.
I don't have any pics of that. And about 27" of some ripped C-Channel i found out in the shed.
I cut the 4" C-Channel to 19", with a 30 degree cut on the side i planned on mating to the 6" channel, and kept the 6" stuff at 3 feet.
Just some pictures of some sweet tack welds.
So next i used some scrap 1/4" Plate i had and made some mounting plates to mount to the stock locations on the frame..
And i levelled the half-channel and tacked it on.
That's what that looks like..
So, after doing that to both sides, i gently placed the C-channel bumper on it to see how it would look. I didn't like how it looked when it was sticking out 8" off the front, plus the added leverage would be a bit too much. So i cut it down to 6" on the mounting, with like a 45" angle on the bottom.
Next, i broke the 2 tacks i put on it off, and laid it back on the ground to cut out the triangles that lead up to the edges. Only used some 1/8th inch stuff because i don't have a plasma cutter, and i had no good right angles to cut off on my 1/4" scrap.
I did this to both sides.
Aaaaand, i didn't take any pictures of the process of making the end's of the bumper. Sorry about that.
Took me about 10 hours to make, not including the blinker mod. I still have to re-inforce the frame as well, and so a bit more bracing on the inside where the C-Channel is welded together. Then i'll paint it and post more pics..
Edit: It looks REALLY wide in those pictures, but it isnt.. it only sticks out an extra 3/4ths of an inch.. roughly stock width from end-cap to end-cap..
oh and sorry about the picture quality.
Old Nov 29, 2009 | 03:24 PM
camo31_10.50's Avatar
heyyyy that looks like a pretty damn good start buddy!!!!
but i wouldnt have made it curve back to the truck so sharply at the sides..but to each their own..and it doesn't look symmetrical..the driver side comes closer to the blinker than the passenger side..atleast it looks like it in the pics..
great start though!
Old Nov 29, 2009 | 03:31 PM
peow130's Avatar
like i said, the picture makes it look bad. i'll get some better ones tomorrow while i'm at school.
it does look funky in that picture, but oh well.
Old Nov 29, 2009 | 03:50 PM
Cascade4Byer's Avatar
hey good job on the bumper. you gonna mount a winch to it?
Old Nov 29, 2009 | 03:54 PM
peow130's Avatar
eventually.
i'll get a locker/bigger tires before i get a winch, though.
Old Nov 29, 2009 | 03:58 PM
yoterr's Avatar
looks good, sorta the direction im gonna go when i get a welder, but in the sec to last pic looks like the blinkers stick out further than the bumper? if it does the first good size tree you try to run over and slides around ur bumper will destroy it....at least thats what im making mine for
Old Nov 29, 2009 | 04:32 PM
peow130's Avatar
That picture is garbage, idk why but the angle of light and the angle of the picture makes everything look strange..
The bumper itself sticks out about the same stock location, right around 3/4ths of an inch off the side of the fender.
my little 110v MIG w/ .035 flux core did well welding that 1/4' thick steel lol.
Old Nov 29, 2009 | 08:18 PM
Stuwy123's Avatar
It looks like James William Bottom-Tooth from family guy.
Sorry.
It looks like a good start. Are you gonna slope the bottom of it and put a hoop/stinger on it?
You could easily make it look like the Warn bumper!
Old Nov 29, 2009 | 08:33 PM
BigBluePile's Avatar
Good start man!
Old Dec 18, 2009 | 09:11 PM
peow130's Avatar
Okay, so i finally got around to finishing this thing up..
My last cut-off wheel exploded so i didnt finish the bracing on the back of the bumper, so it's still a square.
I'll eventually get around to mounting some shackles/D-Rings to it..
Still need to brace the frame
Pics coming, didnt realise they were that flippin huge.
Probably going to turn the triangles in the sides into a toolbox or something
Next up is a locker for the rear. And then come spring i'll be able to do some serious wheeling
Old Dec 18, 2009 | 09:26 PM
peow130's Avatar
Also, dont mind my booger welds
Old Dec 26, 2009 | 08:56 AM
Teuf's Avatar
Man Peeeeeerty cool.
Old Dec 28, 2009 | 04:22 PM
peow130's Avatar
Thanks.
Eventually i'll cover the top with some diamond plate and put the sides as toolboxes, and the middle as a winch.
Old Jan 4, 2010 | 02:42 PM
rjfortuna's Avatar
Looks real good. I love welding. Wish I could do it for a living. I'm going to fab a winch mount for the front of my truck. Probably just stick it out front. I've got a bunch of heavy steel to attach to and a bunch of scrap in the back yard. Oh....I wish I owned a plasma cutter........
Old Jan 5, 2010 | 06:13 AM
black_flag's Avatar
hey! doing the same thing for my senior project, not as elaborate...doing more of a brush guard thing but still awesome. Looks great on your truck. nice job man.
Old Jan 5, 2010 | 06:59 AM
4rnrlvr's Avatar
Looks great!! Can't think of a more fun thing to do for a senior project! I'm kinda jealous...but then again, we didn't have senior projects.
Old Jan 5, 2010 | 05:45 PM
peow130's Avatar
Thanks guys, i wish i owned a plasma cutter too.
And i almost made a flatbed for my senior project, as well as almost using my CJ2A as a senior project, too.
Also, my bumper really isn't that elaborate at all.
30 degree cuts on the end pieces, 3 feet of 6" channel in the middle,
6" away from the front.
Relatively simple
It's actually about 100 pounds, too.
Also: Some glamor shots of before i painted it up.
Old Mar 7, 2010 | 04:32 PM
peow130's Avatar
<flashforward a few months>
Capped off the top with some 1/8th inch thick diamond/plain plate.
Old Mar 7, 2010 | 05:18 PM
vital22re's Avatar
totally a bro
how many mounting points are there?
Old Mar 7, 2010 | 05:27 PM
toyospearo's Avatar
Looks great! Follows the truck front contour perfectly!
Nice work.
