Black diamond plate?
Old Dec 29, 2009 | 10:10 AM
ARK_SWAMP_RIDER's Avatar
I'm looking to fab up a skid plate for the front of my 4runner. This is meant to be somewhat functional, but I'll be the first to admit it's mainly for appearance. I will be needing a piece of diamond plate. I'm not sure on the size, somewhere around a 2'x2' piece. I'm gonna do some measuring to get the exact size, and also gonna have to make a few cardboard templates to see what design I wanna use. Anyhow, since my 4runner is black and I'm not a fan of "bling", instead of using standard diamond plate I am wanting to use a gloss black. However, I've been unable to find this for sale as a sheet anywhere. Can anyone point me in the right direction for this? I was thinking about getting a standard piece and using either undercoating or the herculiner, but I am not sure how well it'll stick on and hold up (not gonna be abusing it, but still want it to last). Here is a pic of the type I'm wanting:
http://www.rockcrawler.com/features/...amondplate.jpg
Can anyone help me find some of this (that hopefully doesn't cost an arm and a leg)? Thanks!
Old Dec 29, 2009 | 10:20 AM
camo31_10.50's Avatar
why not just paint the normal diamond plate.......
Sand, Paint with Gloss Black, let dry, bolt on.....
Old Dec 29, 2009 | 10:21 AM
peapicker's Avatar
Probley gonna have to find a metel supplier in your area, I would go with 1/8 or 3/16 thickness in steel dimand plate. Dont use aluminum. Cost more and would bend alot easier.
Old Dec 29, 2009 | 11:40 AM
Teuf's Avatar
Keep it natural
Old Dec 29, 2009 | 01:14 PM
My 03 4runner is my daily driver, rarely sees any off road. I've got a 87 4runner I use on the weekend to play around with. So, as I said this is mainly for looks. I think aluminum should be lighter which isn't a big deal but a plus. The aluminum bends easier which is a huge plus because I'll have to make several bends in order to get the look I want. I'm pretty sure I'm doing the 1/8 inch to also help with the bends and it will be plenty for what I want. The added toughness of steel and a thicker piece really wouldn't benefit me. As far as sanding then painting a gloss black, I can do that, I just wasn't sure how well the paint would stick to the surface. Also, do any of you have any advice for making a couple bends? It'll need a bend all the way across at the top and bottom, maybe at a 45 degree angle or so. Any tips? Thanks guys!
Old Dec 30, 2009 | 05:16 AM
Bandit Runner's Avatar
Painted diamond plate
Just paint the diamond plate. I used 1/8" thick steel diamond plate in my sliders, and painted them flat black. They turned out great, and are holding up really well.
On the truck:
Old Jan 4, 2010 | 02:37 PM
rjfortuna's Avatar
Bandit, Those came out amazing.
Old Jan 5, 2010 | 08:43 AM
Thanks, here's the build thread if your interested:
https://www.yotatech.com/forums/f2/c...s-pics-182374/
Old Jan 5, 2010 | 11:25 AM
rjfortuna's Avatar
Great build! What did you cut the diamond plate with? Plasma cutter? Looks real clean. I dont have one but want one BAAAAAAD.
What did the custom sliders run you if you dont mind my asking?
Old Jan 8, 2010 | 06:30 AM
Everything I've read says you can use a fine tooth blade on a jig saw and it should cut well. I've spoke with a local shop and can get the regular diamond plate, I may do that and try painting it. However, I'd really like something more durable such as an anodized black.
Old Aug 2, 2011 | 02:58 PM
Thegutted4's Avatar
go to quickshipmetals.com they have black diamond plate you can order
Old Aug 2, 2011 | 03:06 PM
SCToy's Avatar
If you are planning on welding it, you will have to anodize it after that.
Old Aug 4, 2011 | 11:58 AM
E-ROC's Avatar
buy a chunk, cut it to shape, pre-assemble for proper fit, remove, powdercoat, reinstall, enjoy.
bhaithc
Sep 17, 2015 07:53 PM
JHalcyonM
Sep 14, 2015 01:10 AM
LJR
Sep 5, 2015 06:02 AM
