axle swap
Old Nov 5, 2006 | 12:13 PM
csaalways2004's Avatar
Post axle swap
I got an 89 2wd. back in the 80s toyota went from a 55" rear end to a 57" rear end in the 4wd trucks. i am going to put one of those axles in my truck for the spring over setup which will give me 3" or 4" of lift. when toyota switched form the 55" to the 57" were the axle perchs moved or will the 57" fit in my truck even if it has the suspension setup for the 55" rear end? i want to get a spring over setup in the rear and do a spindle lift in the front.
Old Nov 5, 2006 | 05:23 PM
Yoda's Avatar
I know the narrow and wide rears have the same spring perches for a 4X4. Don't know if it is the same as 2 wheel drive though.
Old Nov 6, 2006 | 05:11 AM
4rnr's Avatar
58" not 57"
should bolt up
Old Nov 6, 2006 | 01:37 PM
58" sorry, so it should bolt into the 55" suspension?
Flying91
45
Apr 11, 2024 04:39 PM
polo451
13
Nov 20, 2016 07:49 PM
deepmarsh
Aug 6, 2015 03:44 AM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
yourrealdad
Jul 21, 2015 11:13 AM
