$10 Hi-Lift jack tube mounts.
Old May 19, 2011 | 02:23 PM
Zelephant's Avatar
Earlier this week, it occured to me just how easy it would be to make the tube mounts that Hi-Lift sells for their jacks myself for just a few bucks. My hi-lift just takes up space in my already crowded workshop, so I was anxious for a cheap way to get it on the truck. I repeat that this is so simple, I searched briefly to see if it's been done before. I didn't see anything, so here's my mounting solution.
First, here's Hi-lift's product:
Amazon Amazon
That's more than the jack itself (Harbor Freight special), so those were out. Nevertheless, that's the type of mount I wanted.
The parts list is as follows:
-2 2" exhaust clamps
-2 1/2x2" bolts
-2 1/2" wing nuts
-1/2" ID rubber tubing (they wouldn't sell me less than a foot)
Cut the tubing to properly sized spacers. My thinking is that the rubber will eliminate vibrations. Cut a longer piece than you need, the rubber compresses. Mine ended up being a bit more than 1 1/4":
Cut the heads off the bolts:
Weld the headless bolts to the exhaust clamps. Make sure they're straight and centered:
And now they're ready to go on the truck! I painted them, but it's not really necessary:
And finally mounted! Getting these centered just right so the jack just dropped over the studs probably took longer than actually fabbing them up:
Hope this helps somebody!
Old May 19, 2011 | 04:42 PM
Adk_Yota's Avatar
Great Idea!
Old May 19, 2011 | 05:14 PM
snobdds's Avatar
Very nice. I love seeing other's ingenuity.
I know what I will be making soon.
Old May 19, 2011 | 05:18 PM
MKtaco_98's Avatar
Looks good, that's a real good idea
Old May 19, 2011 | 05:30 PM
87 Deathtrap's Avatar
That's a great idea! I did something similar on an old rig by welding bolts to the roof rack, but this is way better because you can move your mounts if it gets in the way. I'll be making some up this weekend!
Old May 19, 2011 | 05:31 PM
waskillywabbit's Avatar
Great idea. The bolts welded look susceptible to vibration stress fractures.
Use a bigger welder.
Other than that looks good
:wabbit2:
Old May 19, 2011 | 06:21 PM
scottishb's Avatar
Nice! I wonder if they make longer u-bolts... for those that don't have a welder...
Old May 19, 2011 | 06:45 PM
ToyoTech559's Avatar
awesome idea. i will need one once i buy a hi lift jack and some sliders.
Old May 19, 2011 | 06:46 PM
Zelephant's Avatar
Wow, thanks for all the comments! It's always encouraging to have a good idea for a change!
I drove the truck a bit this evening, no vibrations at all from the jack, and I hit some potholes! I think my rubber spacers are working.
Unfortunately, all I have is my little 90A buzz-box, and I didn't even have it turned up all the way. I was told that if you have rainbow discoloration on the back of your weld, then your penetration is good, and I had that.
I'll run the mounts as is, and if they break, it's easy enough to repair or replace them.
Thanks for the feedback, Wabbit. I am still a rookie welder and grateful for any help !
Old May 19, 2011 | 07:04 PM
scuba's Avatar
This is true for the most part. But I only see discoloration on the thin clamps and not on the thick bolts. Not to mention, the welds look somewhat boogery.
At least its not structural.
TheBFA
Feb 15, 2020 06:55 AM
Badlander
Oct 10, 2015 08:05 PM
mreagen
Oct 5, 2015 04:27 PM
dguzzi
Sep 3, 2015 08:48 AM
Ryall
Sep 2, 2015 06:48 AM
