Trucks, 3rd gen-'89 to '95 Post your trucks here
Snorkeldepth's Profile
Old Sep 19, 2005 | 07:53 PM
Snorkeldepth's Avatar
I've had my 1990 SR5 V6 5 Speed Standard Cab Short Bed 4x4 since day one
Here's a brief history:
Put Bilsteins on after about two years
Head Gasket at 110k (covered under warranty)
New CV joints at 150k (got Aisin manual hubs too - I had fixed hubs)
New pedal hanger bracket at about 160k (cracked in left upper corner rendering clutch pedal useless . . . the dealer said they sell a lot of these??)
New clutch, synchros, bearings + retip at 180k
New radiator at 200k (pin hole in top)
New cat back exhaust at 190 k (hole in muffler - Jardine made me the cat back for free!)
New paint at 200k (more of a dent issue than paint issue - I went from black to white too (industrial Imron)! + replaced stock bed liner with Line X and added a SnugTop. New Marlin sliders will hopefully solve future dent problems.)
New ac/heater fan controller whatchamacallit (so the fan works on all speeds)
New idler arm at 210k (fixed front end clunk)
New rear slidiing window (after someone decided they liked my truck more than I did)
New EGR modulator at 150k
Disconnected brake fluid level sensor at 170k (apparently a bad sensor affects the cruise control. Solution = disconnect the sensor)
New starter brushes at about 180k
2 New water pumps replaced at the same time as the timing belt due to cracks
New shift lever bushings at ???
4Crawler 1" BL installed at 227,949k (Only issue was 2nd gear . . solved by trimming the metal boot retaining plate [tin snips, dremel grinder, sand paper]
Reappearing EGR code at 22?k was solved after I found a clogged EGR VSV.
ISR from Cootees installed. It still needs a little fine tuning . . . . actually cutting.
New speedometer cable installed at 236K, finally resolving that intermittent nasty noise from behind the instruments.
This is all I can remember at the moment. The list doesn't include all the general maintenance stuff like brakes, filters, plugs/wires, light bulbs, gaskets, battery, etc.
Update July 18, 2006
Jasper 3VZE installed with Downey headers and custom exhaust. Injectors were cleaned and balanced. Alternator got a tune up. New OEM starter. New OEM clutch and flywheel. New OEM fan pulley bracket. New water pump. Many parts were replaced that showed wear including hoses, all belts, motor mounts, knock sensor and wire, valve covers, etc. Jasper required a new OEM oil cooler. 4.88 gears were installed front and rear with ARB lockers in both. All bearings, bushings, and seals that were removed during the job were replaced with OEM new.
The BudBuilt crossmember/skidplate with 1" drivetrain lift is in. I'll have the front skid in soon. The Sonoran Steel IFS truss is in.
I'm working on getting the WabFab Optima mount installed. I have the diff breather parts to put in. My VIAIR system is waiting for installation
Word has it that the Marlin bumpers I ordered 12 weeks ago may be ready in the fall sometime.
Running BFG AT KO 31 x 10.5 15 on the DD rims . . and 33 x 10.5 15 on the second set of rims I just got.
My dash is currently disassembled. The longer it stays disassembled I'm convinced I'll go with a very simple interior. I removed all the carpet from the floor and the back of the cab. It's just huskyliners on the floor now. The door panels are off (I put the armrests back on the bare doors). I'm thinking of sheet metal door panels. I have the OEM dash speaker boxes I may put back in with speakers in the doors and behind the seats in boxes. I'm dreaming of a completely redesigned dash and instrument panel. I have a Cobra CB waiting to be installed.
I am thoroughly grateful to:
Chris at Rock Tech Offroad in La Habra
Great talent and creativity. Lot's of offroad experience and wisdom that helped in too many areas to mention. Willing to go above and beyond expectations to make things work and get things done right. Very fair prices.
Toyota of Dallas (especially Jacque!)
Awesome customer service and great prices.
My brother Bud at BudBuilt.com
Great products that bolt in with minimal effort. Really nice designs that work well and will stand up if I ever need to go to war in this truck. Bud's a great guy and his customer service is over the top!
Steve at Sonoran Steel
The IFS Truss is as beefy as anyone's imagination could churn out.
Brian at WabFab
Innovative design solutions to problems. Willing to go the extra mile when problems arise and make sure things are 100% right.
The YotaTech Community
Continuously helped me through all the bumps and glitches with this project. My truck will truly be a 1990 Toyota YotaTech Edition 4x4!
Please abide by the administration's rules of this section and DO NOT post in this thread
Old Jul 18, 2006 | 09:07 PM
Bump for the July 18 update!
. . . and I finished the day by reinstalling the grille, putting in the new accelerator cable (that arrived today along with the grille clips) and reinstalling the stereo!
Old Aug 29, 2006 | 12:49 PM
Winner of the coveted, randomly selected, "Featured Rig" on YT! Check out the current pictures at https://www.yotatech.com/forums/f144/featured-rig-week-8-28-06-snorkeldepth-93491/.
I was a little hesitant to accept the honor. I haven't finished the interior and none of my "sponsor" stickers are on the truck yet. Oh well, at least folks can see a real world work in progress.
Whenever I need to come up with my goal for the truck I think of the phrase "Adventure Access Vehicle." Basically, what this truck has always been for me is a way to get to adventures and a way to get me home. It hasn't let me down yet!
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Swampwalker
Oct 12, 2015 09:49 AM
AndYota
Aug 10, 2015 09:19 AM
