Washington Washington Chapter
Washington Wet Wheelers
Old Sep 12, 2014 | 05:53 AM
  #381
SqWADoosh's Avatar
Originally Posted by helipilot77
Hope this helps.
He lives! You the man per usual Nate. We all miss wheeling with you brother. Get that school finished up so you can give those new parts a test run!
Old Sep 12, 2014 | 06:52 AM
  #382
helipilot77's Avatar
I went for a test run at little Naches last weekend my wheel spacers keep coming loose so I ordered some replacements yesterday. I also destroyed my motor mounts (way too much torque). Next project: narrowed FJ-80 full float e-locker rear axle / front e-locker FJ-62 axle.
Old Sep 12, 2014 | 06:56 AM
  #383
MudWash's Avatar
Hope this helps.
Your a lifesaver. That is going to help alot. Thank you helipilot77.
Old Sep 12, 2014 | 07:23 AM
  #384
SqWADoosh's Avatar
Sorry to hear about your continuous wheel spacer issues. Glad to hear you found some time to wheel though. Who made the wheel spacers you are having so much trouble with? That way I know who not to go with when I order mine. Is it the spacers that are the issue or the nuts?
Old Sep 12, 2014 | 07:37 AM
  #385
It is the nuts that keep coming loose. I can't blame Marlin for that. He doesn't make them anymore anyways. I think my problem was not using locktite.
Old Sep 12, 2014 | 07:45 AM
  #386
SqWADoosh's Avatar
Yeah I think that happens to anyone that doesn't use locktite. So did they get damaged when they came loose? Is that the reason for ordering new ones?
Old Sep 12, 2014 | 07:58 AM
  #387
Yeah. A couple of the wheels studs got messed up too.
Old Sep 12, 2014 | 07:59 AM
  #388
SqWADoosh's Avatar
Yikes. How did it make it all the way home in that condition? Or did you not find the damage until you were back?
Old Sep 12, 2014 | 08:27 AM
  #389
I just pulled over and cranked em down as tight as I could. I actually broke two of the wheel studs off. It ovaled out the holes in it, so it definately needs to be replaced. I went with the synergy 1-1/2" wheel spacers that Low Range Off-Road sells.
Old Sep 12, 2014 | 08:34 AM
  #390
SqWADoosh's Avatar
Are you going to try some locknuts this time? Maybe like so
http://monsterfastener.com/item/lns8...cOoaAvfa8P8HAQ
Old Sep 12, 2014 | 08:49 AM
  #391
That would be a good idea if they had a tapered leading edge. It would work great to back up the regular lug nuts with these tightened behind them, if there were enough threads...but there isn't. I'll just use locktite.
Old Sep 12, 2014 | 08:57 AM
  #392
SqWADoosh's Avatar
Fair enough.
Old Sep 30, 2014 | 11:14 AM
  #393
SqWADoosh's Avatar
Was just told I have to work this weekend. Pushing the Walker trip to next weekend probably. Stay tuned for a definitive date.
Old Sep 30, 2014 | 11:33 AM
  #394
Ol'Greeny's Avatar
I think I can make this walker run. I'll see If I can get some buddies too. My front axle has been making a noise so I'll see if I can find what it is.
Looking forward to going wheeling with you guys!
Old Sep 30, 2014 | 11:34 AM
  #395
SqWADoosh's Avatar
Right on brother. Hope to see you there!
Old Sep 30, 2014 | 11:35 AM
  #396
Ol'Greeny's Avatar
Is anyone near bellingham that could help diagnose the noise?
Old Sep 30, 2014 | 11:42 AM
  #397
SqWADoosh's Avatar
I don't believe we have anyone that far north. Can you make a video of it? Or at the very least describe the noise and the conditions in which it is occuring? Usually noise out of the axle is a differential problem.
Old Sep 30, 2014 | 11:45 AM
  #398
Ol'Greeny's Avatar
There has been no shavings out of the dif. Birfields looked perfect. It sounds like it grinding only when I'm climbing over something which is making me think it is just a tire rubbing. Because I can be in 4wd getting on it on flat ground and nothing...
Old Sep 30, 2014 | 11:51 AM
  #399
SqWADoosh's Avatar
Just need to have someone watch your tires as you wheel I guess.
Old Sep 30, 2014 | 01:53 PM
  #400
B-Fake's Avatar
Probably just your tire rubbing somewhere in your wheel well. Same thing happened to mine, sounded just like a CV joint about ready to blow up.
