California NorCal California NorCal Chapter
Ac heater blower
Old Nov 30, 2011 | 07:05 PM
85CamoYota's Avatar
Ac heater blower
I got in my truck the other day and my heater would not come on and im not sure why but i think its the blower motor and i dont know how to fix it can any body help me with any info
Old Feb 20, 2012 | 09:39 PM
stovetop36's Avatar
If your lucky and it is just the blower motor its not a hard swap.Based on your username you have an 85 yota which should be similiar to my 86 4runner. Of course check all your fuses and relays. When you go to turn on the system you should hear a quiet click when the relay switches on. The blower motor is located behind the glove box, open the glove box the pop the leather shroud down. You will have to flex the glove box to get it to drop out and then you will have access to all the heater parts. The relay and some more fuses are located back here. You have also just unlocked really good access to the back of the dash for future repairs. You should then be able to unplug everything, unbolt the blower and make the swap. I have seen a really good write up on the forums before that showed how to service your blower and might be worth an hour of your time first. Good luck!!!
kawazx636
Oct 6, 2021 03:03 PM
woodyth
Sep 30, 2015 06:32 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
Kreedy1
Sep 8, 2015 06:33 PM
--Oz--
Sep 6, 2015 01:06 AM
