Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Universal 4 Link Suspension Kits from Barnes 4wd!
Old Jul 7, 2016 | 04:21 PM
Barnes 4wd's Avatar
FormerVendor
Universal 4 Link Kits from Barnes 4WD!
All kits ship with brackets drilled to the correct bolt hole size and no extra cost!
This is the kit that has all the parts that we are always using in the shop for customers single triangulated four links suspensions. It is made to stand up to all the abuse that rock crawlers and weekend warriors put their rigs through, and everything else in between. It includes:
1 x Axle Link Mount Pair 0 Deg
1 x Truss Link Mount Brackets
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 20 Deg
4 x Chromoly 1 1/4"- 12 X 1" Heim RH
4 x Chromoly 1 1/4"- 12 X 1" Heim LH
16 x High Misalignment Spacer - 1" to 9/16"
4 x 1-1/4" - 12 Jam Nut RH
4 x 1-1/4" - 12 Jam Nut LH
4 x Tube Insert (1-1/4-12) 1 1/2" ID Tube RH
4 x Tube Insert (1-1/4-12) 1 1/2" ID Tube LH
Add Grade 8 zinc plated hardware
We Also have Triangulated Lowers or Double triangulated 4 link kits!
Double Triangulated Four Link Suspension Kit 1 1/4" Chromoly Heims
Lower Triangulated Four Link Suspension Kit 1 1/4" Chromoly Heims
Enduro Joint 4 link kit
Old Jul 9, 2016 | 07:39 AM
Barnes 4wd's Avatar
FormerVendor
We know the importance of a good articulated rig
Old Jul 19, 2016 | 08:44 AM
Barnes 4wd's Avatar
FormerVendor
Another busy Tuesday, thanks Yota Tech!
Old Jul 24, 2016 | 06:16 PM
Barnes 4wd's Avatar
FormerVendor
We only make parts that you can trust!
Old Aug 5, 2016 | 06:00 AM
Barnes 4wd's Avatar
FormerVendor
We love staying busy! Thanks everyone!
Old Aug 11, 2016 | 04:32 PM
Barnes 4wd's Avatar
FormerVendor
Friday is right around the corner!
Old Aug 19, 2016 | 12:32 PM
Barnes 4wd's Avatar
FormerVendor
Another busy week in the books!
Old Aug 26, 2016 | 11:37 AM
Barnes 4wd's Avatar
FormerVendor
Thank you for another busy week everyone!
Old Sep 1, 2016 | 03:22 PM
Barnes 4wd's Avatar
FormerVendor
The weekend is almost here!
Old Sep 13, 2016 | 04:06 PM
Barnes 4wd's Avatar
FormerVendor
Busy week thanks to you!
Old Sep 20, 2016 | 03:52 PM
Barnes 4wd's Avatar
FormerVendor
Let's get those orders in!
Old Sep 29, 2016 | 02:56 PM
Barnes 4wd's Avatar
FormerVendor
Get the parts you need at prices you can afford!
Old Oct 7, 2016 | 11:41 AM
Barnes 4wd's Avatar
FormerVendor
Thanks for another busy week! We couldn't do it without you guys!
Old Oct 26, 2016 | 07:24 AM
Barnes 4wd's Avatar
FormerVendor
We are running at full pace today!
Old Nov 3, 2016 | 02:17 PM
Barnes 4wd's Avatar
FormerVendor
Old Nov 15, 2016 | 02:12 PM
Barnes 4wd's Avatar
FormerVendor
Oh yes, you know you want it
